Gen 3 clutch problem
  • JackBates
7 years 2 months ago #213084 by JackBates
Gen 3 clutch problem was created by JackBates
Hi guys!
I have a gen4 but the girlfriend is after a gen3 after falling in love with mine.
Test drove one today and the clutch was hurrendous. 90% of the travel was floppy with no action on the clutch and no sort of resistance. The last 10% is stiff and have to jam the pedal into the floor to disengage the clutch to change gear.
Is it a cable actuated clutch on these or hydraulic? Is there any kind of adjustment that could solve this? Sound like air in the system if hydraulic? From my experience of classics I would say the clutch is worn to bones but not having any specific jimny knowledge wanted to ask here incase this is known of.
If clutch is gone, what's the average cost for replacement in these?
Thanks in advance!!
Jack
Sent from my Nokia 7 plus using Tapatalk
  • JackBates
7 years 2 months ago #213085 by JackBates
Replied by JackBates on topic Re:Gen 3 clutch problem
Would help to add some vehicle information haha
2006 with 111k
7 years 2 months ago #213086 by mlines
Replied by mlines on topic Re:Gen 3 clutch problem
It's cable and there is some adjustment on the end under the car
The following user(s) said Thank You: JackBates
  • JackBates
7 years 2 months ago #213087 by JackBates
Replied by JackBates on topic Gen 3 clutch problem
mlines wrote: It's cable and there is some adjustment on the end under the car
That's great thanks!
Would you say it's a stretched cable sounding deal or clutch at end of life? Are they characteristically heavy on the gen3's?
7 years 2 months ago #213088 by mlines
Clutch itself does wear and get mud on the splines.
The cable is lined with nylon which wears through on the curves making the cable heavy and stick
7 years 2 months ago - 7 years 2 months ago #213090 by Scimike
Replied by Scimike on topic Gen 3 clutch problem
They are not heavy in use. The cable can be adjusted at the gearbox end, turn the plastic nut type adjustment. 10mm of "free play" until you feel the pressure increase (measured at foot pedal tip). Note "free play" is still on the pedal spring return, so it's not sloppy, but when pressed you can feel the point (10mm) at which the clutch arm starts to move the clutch plate.
Could be shot cable as Martin said. I would think it would feel similar to your GEN4 unless it's an auto.
Last edit: 7 years 2 months ago by Scimike.
