Cable entry from engine to cabin ?
  • Blackout
22 Aug 2019 15:25 #212515 by Blackout
Cable entry from engine to cabin ? was created by Blackout
Hey all. Trying to run a relay to the rear door to mount my spotlight. What’s the best / easiest method to get from the battery to inside the cabin. There seems to be a rubber circular thing with cables coming from the engine bay... pierce this and run through ? Or am I missing something obvious
22 Aug 2019 15:44 #212518 by Lambert
That's the route i used. It's a bit of a faff to feed through so I used a wire coat hanger.
  • Blackout
22 Aug 2019 16:00 #212521 by Blackout
Replied by Blackout on topic Cable entry from engine to cabin ?
Was hoping there was another way some how gotta feed all this through :(
22 Aug 2019 16:13 #212523 by jackonlyjack
I used Lambert's method till i could not get any more through
After that i drilled a hole and used a cable gland :woohoo: :whistle:
22 Aug 2019 16:16 #212524 by Lambert
That's going to be fun. Is there any way to remove any of the terminals to reduce the insertion aperture?
  • Blackout
22 Aug 2019 16:55 #212527 by Blackout
That block does not want to play ball. Might just get a new harness
Time to create page: 0.094 seconds
