Cable entry from engine to cabin ?
22 Aug 2019 17:08 #212529
Replied by jackonlyjack on topic Cable entry from engine to cabin ?
The crimps in the block will have a barb possibly down the back
use a paper clip but first make it flat using a hammer then push it down from the front and pull steady on the wires
22 Aug 2019 19:01 #212540
Replied by Soeley on topic Cable entry from engine to cabin ?
When I fitted a temp gauge to my last car I had to get the sensor end through a similar grommet. So I used a sealant nozzle and some WD40, it went in like a hot knife through butter.
- Thank you received: 1999
22 Aug 2019 19:04 #212541
That's clever. I'm stealing this idea for the future.
Replied by Lambert on topic Cable entry from engine to cabin ?
Soeley wrote: When I fitted a temp gauge to my last car I had to get the sensor end through a similar grommet. So I used a sealant nozzle and some WD40, it went in like a hot knife through butter.
- Blackout
22 Aug 2019 19:42 #212544
by Blackout
Replied by Blackout on topic Cable entry from engine to cabin ?
That’s a great idea! Did you have to cut the grommet? I have fear of nicking one of the wires as I cut, guess I could pull it back a bit
- Podge
22 Aug 2019 20:00 #212549
by Podge
Replied by Podge on topic Cable entry from engine to cabin ?
I used one of the grommets that had the wiring loom under the ABS pump.
You can push it through from the engine bay but my grommet had a tape seal on the inside which wouldn't let the grommet stretch and the cable been pushed through. Once it was off it was easy to push the cable through .
22 Aug 2019 20:01 #212550
I just punched through first with a small electricians screwdriver.
Blackout wrote: That’s a great idea! Did you have to cut the grommet? I have fear of nicking one of the wires as I cut, guess I could pull it back a bit
