Transfer box
  • Basketcase
14 Jun 2019 13:16 #209939 by Basketcase
Transfer box was created by Basketcase
Hello guys the transfer box chain has started slipping now nice clunking noise when setting off..is it worth changing the chain and gears for new ones or just get a 2nd hand box and throw that on? It’s a 2000 reg jimny so obviously don’t want to spend hundreds on parts for it. Any opinions or anything greatly appreciated. Cheers
14 Jun 2019 14:29 #209941 by Lambert
Replied by Lambert on topic Transfer box
Unless you're looking to regear it I'd say just get another box.
  • Basketcase
14 Jun 2019 14:33 #209942 by Basketcase
Replied by Basketcase on topic Transfer box
It could do with better ratio but if the only ones are jimnybits then I won’t be spending that much on gearing
14 Jun 2019 15:05 #209944 by me101
Replied by me101 on topic Transfer box
I went for a quick box replacement due to needing it back on the road. But I have kept the old box so I can put a new chain on it (as I suspect the chain on my replacement will probably go the same way!) If you can do it yourself, think a new chain would be cheaper.
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
  • Basketcase
14 Jun 2019 15:10 #209945 by Basketcase
If the only place you can get the chain from is jimny bits then definitely not...chain is£100 and it’d need new gears too I assume they are £300
14 Jun 2019 15:12 #209946 by me101
Ah, I thought you could get away with the original gears.
Time to create page: 0.108 seconds
