Power steering fluid change
05 Apr 2019 14:08 #205567
by BGBrit
Power steering fluid change was created by BGBrit
Hello all, I've just bought two litres of Bardahl ATF 6 synthetic oil to replace the fluid in my 2009 Jimny does anyone know if that's enough or do I need another litre or two, I can't find anywhere that states the quantities. Also am I using the right oil for this job. Thanks in advance.
06 Apr 2019 08:29 #205596
by Scimike
Replied by Scimike on topic Power steering fluid change
Hi,
Had a good look in my owners manual and the technical data I have but none gives a quantity for the power steering fluid. Suzuki recommend Dexron 3 PSF which does not exist, Dexron 3 is a ATF fluid so I suppose this is a Suzuki typo, and most fluids of this type can be used in both ATF and PSF applications anyway.
And now the googled bit:
ATF Dexron III is a synthetic based automatic transmission fluid
Primarily designed for use in automatic transmissions in severe operating conditions such as those
fitted on busses, commercial vehicles and off highway equipment along with high performance
passenger cars. The fluid may also be used in the majority of power steering systems.
Performance Specifications
General Motors Dexron III Allison C4 (Automatic Transmission) Allison TES-389
Mercedes Benz MB 236.1 Mercedes Benz MB 236.9 Volvo 97341
MAN 339-V2 /339-Z2 Voith DIWA H55.6336.3X (former G1363) (120000km drain)
ZF TE-ML 04D (Marine Transmissions)
ZF TE-ML 14B (60 000km drain)
ZF TE-ML 16L (rail vehicle transmissions)
It's nothing special so it would appear any synthetic ATF fluid will do the job, but if you want similar try to match the specs above.
Don't known if this helps, hope so.
Good luck
Mike
PS do you have working Aircon on your 2009? If so I could do with you taking a look at something under the bonnet when it's running. Mine is also a 2009 and I am not sure if the Aircon compressor should be engaged all the time or pulse off on. If you can help I can explain better, if you can't no problem.
Good luck
Mike
The following user(s) said Thank You: BGBrit
06 Apr 2019 08:51 #205597
by BGBrit
Replied by BGBrit on topic Power steering fluid change
Thank you for that info mate!! Yes my 2009 has air-con fitted. I will check if it stops and starts or is continuous running. I've not noticed or looked into that before. I'm incapacitated at the moment lying flat out with a puled back muscle. Hopefully by Monday I'll be up and about, so I'll get back to you on the air-con.
Once again thanks for the info..
Tony
Tony
06 Apr 2019 10:30 #205601
by Scimike
Thanks Tony,
Appreciate you taking a look, but no rush, get yourself better first.
If you will I need you to look at the aircon compressor pulley with the engine running. Normally (Aircon off) the pulley outer will rotate but the inner will not, it's an electric clutch. When you turn the Aircon on the pulley inner is electrically engaged to the outer so it all rotates, easy to see.
So my question is with your Aircon on ( run it for a minute or two ) does the pulley remain engaged continually or does it click in / out at any point during this time?
Trying to regas mine but find I can get it to run continually or click in /out depending upon the gas charge I put in it. Trouble is I can't get a proper pressure indication and so just want to know which way to bias the charge by comparison to a working system.
Thanks
Mike
Thanks
Mike
06 Apr 2019 10:47 #205602
by BGBrit
Okay Mike... Got all that I understand what you need..and I'll see if I can do that tomorrow for you (Sunday) if not certainly by Monday.
Tony.
Tony.
- Cremator1
06 Apr 2019 19:44 #205623
by Cremator1
Replied by Cremator1 on topic Power steering fluid change
It should click in and out
Time to create page: 0.172 seconds
