Power steering fluid change
13 Apr 2019 14:23 #206001 by Lambert
Replied by Lambert on topic Power steering fluid change
I thought that most power steering systems self bleed when turning to full lock and activating the bypass valve?
13 Apr 2019 16:43 #206009 by BGBrit
Replied by BGBrit on topic Power steering fluid change
Thanks for that. I used up the two litres I had and all works good as before, just a little darker in colour than in the bottle so I might buy another as you suggest and pour that in too. It's a simple enough job to do...
13 Apr 2019 16:44 #206010 by BGBrit
Perhaps but without experience I went for the safe option. Cheers.
16 Nov 2023 17:07 - 16 Nov 2023 17:11 #252160 by Atheling
Ok so thought I'd continue on this old thread as relevant.
Does the PAS reservoir cap come off - and how, unscrew, prise off? I can't budge it either way. Stressing the components - and me! Trying the syringe it out renewal using the filler plug but can only get 50mls or so because of obstructive filter. Take a long time that way.
2010 1.3 VVT Jimny.
Last edit: 16 Nov 2023 17:11 by Atheling.
16 Nov 2023 18:14 #252161 by jackonlyjack
The following user(s) said Thank You: Atheling
17 Nov 2023 16:08 #252174 by Atheling
I'm beginning to think it's welded shut. I cannot shift it with various wrenches tools (jam jar lid remover even!), hot water, hammering rim, wd40. Removed from its brace to avoid breaking the bottle. Humiliation. Maybe 2010 model is different? Anyone confirm it opens on later gen 3s?
Time to create page: 0.666 seconds
