ABS sensor adjustment
  • Don76
05 Mar 2019 20:25 #204156 by Don76
Replied by Don76 on topic ABS sensor adjustment
It’s a strange one. Only comes on at around 63mph. Everything else feels fine. To be honest I am tempted to leave it till I change the discs and adjust them in a bit then. I am not super keen on Jimny driving above 60 anyway, it all seem super to get a bit lively...
  • Dano0404
05 Mar 2019 21:18 #204158 by Dano0404
Replied by Dano0404 on topic ABS sensor adjustment
I have this issue and only just realised after reading it happens at around this speed. Only thing I have done is a 2inch lift though. Was fine after king pin bearings.
  • Don76
06 Mar 2019 19:46 #204204 by Don76
theoldseacaptain wrote: Similar thing happened to me when replacing the Kingpins. I had spaced the sensor too far away from the toothed rotor. Popped the disc and calliper off, adjusted the sensor to 1 to 2mm from the rotor and re-assembled. Not a big job if you've just had everything apart.
Thanks for the info. I re adjusted the passenger side sensor today to around 1mm from the rotor. the ABS system is now running with no issues above 60 mph. :)
06 Mar 2019 19:52 #204206 by Max Headroom
Replied by Max Headroom on topic ABS sensor adjustment
Don76 wrote: I re adjusted the passenger side sensor today to around 1mm from the rotor. the ABS system is now running with no issues above 60 mph. :)
Yaaaay! Great result.
Was it much of a job?
  • Don76
06 Mar 2019 22:47 #204222 by Don76
No it wasn’t much of a job really.
Luckily it all came to bits easy as I had only done the kingpins last week. Kind of sucked having to do it again, especially as i got soaked :laugh: :laugh:
Every day is a school day though.
