ABS sensor adjustment
  • Don76
04 Mar 2019 11:18 #204089 by Don76
ABS sensor adjustment was created by Don76
So I find myself here again, cap in hand ..
I have fitted the new kingpins and all is good. As part of this process I took the ABS sensors off. The ABS system is fine up to 60 mph, then dashboard light comes on. If I stop and start off again it goes off. It’s clear I have one of the sensors to close or too far away from the cog wheel.
Does anyone have experience with this, do I set them as close as possible?
If so can I do this without taking all the disc and Caliper off again. I was thinking of jacking it up and adjusting it closer till I hear it clip when I slowly rotate the wheel then back it off till it goes off. Does that sound reasonable?
Any help greatly appreciated ..
As soon as I stop fixing this rascal I will get round to posting a few pics and intro in the jimny general section.
04 Mar 2019 12:51 - 04 Mar 2019 12:57 #204094 by Max Headroom
Replied by Max Headroom on topic ABS sensor adjustment
I've heard of dirt getting in when sensors have been removed and then refitted which causes problems. Cleanliness with these types of components is essential.
Similarly, corrosion on the actual sensor seating can cause the sensor to not be quite close enough to the rotor.
Sensors are funny things and dont like being disturbed
Last edit: 04 Mar 2019 12:57 by Max Headroom.
04 Mar 2019 13:26 #204096 by Lambert
Replied by Lambert on topic ABS sensor adjustment
I think I read somewhere that the gap should be in the 1mm range. Can't remember where i read that though.
  • mickt
04 Mar 2019 13:59 #204098 by mickt
Replied by mickt on topic ABS sensor adjustment
Strange that it only comes on at 60mph though. If its not gapped correctly then it should come on at trigger speed, normally around 5mph. Perhaps a disc is warping or a wheel bearing is worn and the inbalance at speed is causing the wheel to wander. Any signs of wheel wobble be it slight even?
04 Mar 2019 14:17 #204101 by theoldseacaptain
Similar thing happened to me when replacing the Kingpins. I had spaced the sensor too far away from the toothed rotor. Popped the disc and calliper off, adjusted the sensor to 1 to 2mm from the rotor and re-assembled. Not a big job if you've just had everything apart.
Sadly jimny-less but still got the bug!
The following user(s) said Thank You: Don76
04 Mar 2019 22:13 #204127 by Max Headroom
mickt wrote: Perhaps a disc is warping or a wheel bearing is worn
Actually that's a good point; if the sensor is not sitting close enough to the rotor, I can understand how that could happen
Time to create page: 0.189 seconds
