Re:Diffs VVT on Jimny Non VVT
20 Feb 2019 17:03 #203555
For that tyre size no correction is needed. The 215 tyres are not much larger than standard and the gearing copes nicely with that size. Were you to go to the next size up (235/75r15) you would find it sluggish and it will wear out the clutch much faster (especially if off-roading). Then you need to think about the gearing alterations.
you can look up and compare the actual tyre sizes here:
tiresize.com/tyre-size-calculator/
and the gearing can be calculated properly with this handy website:
www.grimmjeeper.com/gears.html
All the standard gearing specs are listed in the wiki section of this fine site
Wuzie: as mentioned by Sniper, the low box performance wouldnt be good as you are only changing the final drive ratio by doing this. For example; My 07' VVT jimny has a 'rocklobster' transfer box in it (built by a bloke known as 'Rockwatt Engineering'). It has a 1.6 ratio in high box and 5.13 in low-box. Compared to the original with 1.00 in high and 2.00 in low you can see that it has a much greater reduction value for the low ratio gears. This works well with the huge 33" tyres and is the only real way to get it geared properly. Note I am also using the 3.9 diffs and earlier r7me gearbox from the non VVT jimnys to compensate for the rocklobster box (when i tried the rocklobster box in it with the 4.3 diffs and R72 gearbox it was a joke, top speed in high box 5th gear was about 30mph!).
Hopefully this points everyone towards trying to use the grimjeeper site to get the gearing sorted out properly.
Replied by Riccy on topic Re:Diffs VVT on Jimny Non VVT
Lerk wrote: For example, I Will put VVT diffs (4.3) in my Jimny (M16A non vvt) and 215/75/15 tyres.
Enough?
Maybe in a future I put trail gear planetary (-60% low range reduction) but im scared with the transfer chain.....
Enviado desde mi ONEPLUS A6003 mediante Tapatalk
- Wuzie123
- Visitor
26 Jan 2020 21:02 - 26 Jan 2020 21:04 #217716
by Wuzie123
Replied by Wuzie123 on topic Re:Diffs VVT on Jimny Non VVT
sorry to dig up an old thread but im just away to rebuild my diffs and this is still playing on my mind i have added a pic from the Wiki page and from what you guys are saying im confused.
To me if you lower the dif ratio then it works the same in high range or low range.... both will turn the wheel slower as the ratio in the diffs is lower yeah i know the full way to do it is to fit a rocklobster but i aint got my hands on one yet so not an option just now for me.....
Any info would be ace as away to do the VVTI into a 2003 non VVTI manual jimny so the same as the lower box in the pic?
My car is a 2003 Maunal non VVTI Jimny on 31's, and i have diffs from a later VVTI manual Jimny so should be 3.909-4.300 gear change
Regards
Doug
Regards
Doug
Last edit: 26 Jan 2020 21:04 by Wuzie123.
- Thank you received: 923
26 Jan 2020 21:28 #217717
Replied by X8GGY on topic Re:Diffs VVT on Jimny Non VVT
That's exactly what I'm doing with my buggy build... I've replaced the standard 3.9:1 diffs with later 4.3:1 ratio ones, which allows me to fit bigger 29" tyres, so the overall gearing should be close to stock... but as said earlier the low side of the box may still be a bit 'high' as the Jimny has never been much of a rock-crawler, but it should be fine for some greenlaning!
The following user(s) said Thank You: mlines
26 Jan 2020 21:31 #217718
The back diff fitted fine...
The front needed the slots enlarging to fit the bigger crown wheel in though! -
Time to create page: 0.136 seconds
