Re:Diffs VVT on Jimny Non VVT
  • Lerk
  • Visitor
  • Visitor
19 Feb 2019 07:52 #203434 by Lerk
Diffs VVT on Jimny Non VVT was created by Lerk
Hey, good morning.
I bought front and rear diffs from VVT Jimny (43x10 - 4.3 ratio)
My Jimny is Non-VVT , manual gearbox (43x11 - 3.90 ratio).
And my question is...Any put VVT diffs in a Non-VVT Jimny?
I read that rear diff is a simple swap, right? The problem come with front diff, the diff housing is small in Non-VVT Jimny, right?
Is simple to clearancing the diff housing or i need to find a front diff housing from vvt ?
Thanks man for helping.
Lerk.
19 Feb 2019 11:10 #203446 by jackonlyjack
It will be obvious when you try to fit it
You will need to grind a little bit off the diff housing
The following user(s) said Thank You: Lerk
  • Lerk
  • Visitor
  • Visitor
19 Feb 2019 11:36 #203450 by Lerk
Replied by Lerk on topic Re:Diffs VVT on Jimny Non VVT
jackonlyjack wrote: It will be obvious when you try to fit it
A little bit? Hahaha. Easy?
And no problem with axles?
Enviado desde mi ONEPLUS A6003 mediante Tapatalk
19 Feb 2019 15:10 #203456 by jackonlyjack
Yes if you're not confident with grinder you could use a file (this would take time)
when you try to push the diff in to axle case you will see where the diff catches the axle case just grind the axle case to allow it to slide in
only a few mm to remove
  • Lerk
  • Visitor
  • Visitor
19 Feb 2019 16:10 #203458 by Lerk
jackonlyjack wrote: Yes if you're not confident with grinder you could use a file (this would take time)
Perfect, it has already been understood.
Only need to grinder the "front" axle case, right? Rear is plug and play, correct?
Thanks for ur time.
19 Feb 2019 18:14 #203467 by Riccy
Replied by Riccy on topic Re:Diffs VVT on Jimny Non VVT
Dave did exactly that swap in this thread...
www.bigjimny.com/index.php/forum/18-buil...daily-driver?start=0
I have swapped vvt to non-vvt diffs (the other way to you) and had to grind at the front axle casing a wee bit, thus I would assume that going the way you are shouldn't need any extra clearance?
