Dead Jimny Northern Ireland
01 Feb 2019 16:29 #202286
by Jackson
Replied by Jackson on topic Dead Jimny Northern Ireland
Got a report back.
New starter fitted, working 100%. Getting spark and fuel. Jimny will not fire up.
The engine is backfiring through the air box.
Has any one else experienced a starting fault with these symptoms? What should we be looking for? Is it a timing issue? Sensor? Mechanical?
In the mean time we are getting a compression test done to see if that shows up anything...
Any help greatly appreciated. Thanks.
- Thank you received: 1983
01 Feb 2019 17:33 #202289
Replied by Lambert on topic Dead Jimny Northern Ireland
Sounds sensor ish to me cam or crank? cheap enough to swap. Is it giving any codes?
01 Feb 2019 17:38 - 01 Feb 2019 17:39 #202290
by adrianr
About Wee Jimmy : www.bigjimny.com/index.php/forum/8-my-ji...-first-jimny?start=0
Replied by adrianr on topic Dead Jimny Northern Ireland
Can your mechanic run a diagnostic and check any fault codes? Interestingly mine had a misfire and a faulty crank sensor and a vacuum leak that was not causing a fault code.
I'm not 100% sure since I know more about diesel, and I may be wrong, it sounds like the spark is being fired at the wrong time which would point me towards either a cam sensor or a crank sensor.
Can anyone else chime in and help, please?
--EDIT -- looks like Lambert's message arrived as I typed mine
Last edit: 01 Feb 2019 17:39 by adrianr.
01 Feb 2019 17:42 #202291
Sorry!
01 Feb 2019 17:54 - 01 Feb 2019 17:55 #202293
by adrianr
Gosh, no need to apologise. Am glad I was also heading in the same direction with my thoughts.
Last edit: 01 Feb 2019 17:55 by adrianr.
01 Feb 2019 18:02 #202294
by Jackson
Thanks.
No codes.
What makes me think that it is a sensor is that when she fires up (before breakdown) she will run and drive perfect. Its only intermittent non starter.
Is it worth replacing the sensors with no codes showing?
Thanks for help.
No codes.
Thanks for help.
Time to create page: 0.234 seconds
