Axles/Differentials
12 Jan 2019 18:05 #200595 by Riccy
Replied by Riccy on topic Axles/Differentials
OK then, Gearing calculation is the key here.
For the gearing avaliable by swapping different parts about see the wiki here.. www.bigjimny.com/mediawiki/index.php?tit...erential_information
and use that information with a website called 'grimjeeper' to compare the effects of changing any given part. www.grimmjeeper.com/gears.html
with enough work and parts it is possible to swap the gearbox, t-box and diffs between vvt and non vvt. its also possible to swap in a SJ t-box or a rocklobster box for really low drive :-)
very versatile is the Jimny ;-)
12 Jan 2019 18:09 #200596 by Riccy
I realise that doesnt answer your question. Basically anything in the UK with ABS would have suitable donor axle casing from 2001 onwards.
To be certain I would ask for one from a hard top M13 engine'd model.
13 Jan 2019 07:01 #200615 by HUN
Replied by HUN on topic Axles/Differentials
Thanks Riccy. I gonna have a proper look into those link.
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
15 Jan 2019 13:48 #200791 by HUN
Ok then. Here is a quick question: would an 2004 ABS axle change my current gear ratio? I guess yes, because all engine before 2005 were non-VVT. Is it correct?
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
15 Jan 2019 18:28 #200813 by Riccy
The casing would, but the diff will be a 3.9, where you need a 4.3 to keep it the same. You could swap the diffs over, but that means removing the shafts.
The result would be to over-gear the car, making it slow to accelerate and cause clutch wear. You would also need to swap the front to the same ratio diff if you want to keep 4x4 ability.
15 Jan 2019 22:01 #200826 by Busta
Replied by Busta on topic Axles/Differentials
The question nobody has asked yet is what are you hoping to achieve? Are you just looking to replace a damaged axle or are you looking to alter the gearing?
If its the gearing you seek to change you only need to swap the diffs, not the entire axle. All the diffs are interchangeable, so you could buy some '98 diffs and fit them in a 2017 Jimny and vise versa.
Time to create page: 0.101 seconds
