Axles/Differentials
08 Jan 2019 19:40 #200196 by HUN
Axles/Differentials was created by HUN
Hi All.
My Jimny is from 2005. It has M13a VVT engine, R72 gearbox, ABS etc..
Can I fit axles/differentials from a donor Jimny from all year between 1998-2018 or just 2005 and later years? Can I use axle without ABS? Would it pass MOT?
Sorry for my daft questions.
Regards, Gabor
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
08 Jan 2019 20:11 #200203 by Riccy
Replied by Riccy on topic Axles/Differentials
non VVT axles have different diff ratios, but the casings are the same otherwise. if you have ABS then you will need a donor casing from an abs vehicle. Would pass a UK MOT no problem.
08 Jan 2019 20:14 #200204 by Riccy
For example; I have 2007 vvt axle casings but the earlier non VVT diffs and have no issues swapping parts between them all.
08 Jan 2019 20:14 #200205 by Lambert
Replied by Lambert on topic Axles/Differentials
Ideally you are better off with abs axles on an abs car as it's one of the few driving aids actually worth having. Also for the mot it's possible to remove the abs system completely and not get a failure but to have a constant abs warning light on is a failure. There is also the insurance cot notify who will undoubtedly increase the premium.
09 Jan 2019 03:59 #200220 by HUN
Replied by HUN on topic Axles/Differentials
Thanks for this info Guys!
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
12 Jan 2019 17:45 #200594 by HUN
My current understanding of this subject based on what I could read here and heard from others:
Casing had been made either with ABS or without ABS in the past. I should fit only casing with ABS that's for sure.
After about 2004-2005 the engine was made either M13A non-VVT or M13A VVT.
All (M13A) casing size the same but non-VVT has different ratios. What does it mean? Lower or higher?
And what about axles made before 2004? Was all of them wihout ABS therefore those aren't for me?
How many different variant of axle can be found out there? Four or even more? I just cannot get it...
Educate me please...I feel confused.
Thank in advance.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Time to create page: 0.120 seconds
