Problem in gearbox or clutch?
- kriksis
23 Nov 2018 20:01 #198071
by kriksis
Problem in gearbox or clutch? was created by kriksis
Hi,
I gave strange situation.
When car is cold i can shift gears good, but when im driving for ~30min gear change becomes really hard. On reverse, there is grinding noise etc.
Also when i park on slope and leave in gear, car starts to roll. In reverse it stays in place.
Changed oil in gearbox, but it didn't solve anything.
Any suggestions what has gone wrong? Thanks!
- Thank you received: 2004
23 Nov 2018 20:34 #198074
Replied by Lambert on topic Problem in gearbox or clutch?
Sounds like it has the wrong grade of oil in it. It MUST HAVE gl4 specification oil in it not a gl5 or gl4/5 combination oil. The gearbox is very particular about this.
- kriksis
23 Nov 2018 20:44 #198075
by kriksis
Replied by kriksis on topic Problem in gearbox or clutch?
Oil change was done is car service. So i will ask what type oil they put in.
But there wasn't any noticable difference before or after oil change.
- paradox1001
23 Nov 2018 21:35 - 23 Nov 2018 21:37 #198082
by paradox1001
Replied by paradox1001 on topic Problem in gearbox or clutch?
Shouldn’t roll down hill in gear
Is your clutch slipping?
Is this with the handbrake on?
Last edit: 23 Nov 2018 21:37 by paradox1001.
24 Nov 2018 05:46 #198086
If you are stationary and engage 5th gear and lift the clutch slowly, once at the biting point does the engine stall? If yes then the clutch is fine, if the engine keeps running then the clutch is bad. A slight roll that takes up the backlash in the drive system is normal but shouldn't be more than about 150mm.
26 Nov 2018 21:33 #198199
by Delux
Busiest Mechanic in Scotland!
My pics (inc. pics of my latest Jimny project)...
www.flickr.com/photos/159422664@N08/albums
My ebay stuff for sale...
www.ebay.co.uk/usr/deeelux
Replied by Delux on topic Problem in gearbox or clutch?
Lamberts technique is the best for checking the clutch.
If you have clutch problems you are more likely to notice problems shifting in 1st and reverse because there is more torque going thru it.
From your what you describe, your clutch plate might be breaking up rather than worn. You can check for this by resting your foot on the clutch in neutral with the engine running. A pulsing thru the pedal may indicate a problem.
Before you haul the gearbox out though, have a quick look at the clutch fluid level and around the slave cylinder for leaks. Clutch and gearbox may be fine but because the slave cylinder isnt moving enough it shows the same symptoms as not pressing the clutch down fully.
Time to create page: 0.113 seconds
