Problem in gearbox or clutch?
  • Jimx5
26 Nov 2018 21:44 #198200 by Jimx5
Replied by Jimx5 on topic Problem in gearbox or clutch?
I thought the clutch was cable operated.
Or is it because mine an 04 reg?
26 Nov 2018 21:53 #198201 by Delux
Replied by Delux on topic Problem in gearbox or clutch?
LOL! Yeah, Jimnys have cable clutches! My memory appears to be working on something with a hydraulic clutch.
(Gets coat, tip toes away...)
Busiest Mechanic in Scotland!
My pics (inc. pics of my latest Jimny project)...
www.flickr.com/photos/159422664@N08/albums
My ebay stuff for sale...
www.ebay.co.uk/usr/deeelux
  • kriksis
26 Nov 2018 22:43 #198205 by kriksis
Replied by kriksis on topic Problem in gearbox or clutch?
Tested in 5th gear and car stalled right away.
I didnt had a clutch cable cover (plastic thingie) for quite a while. Could that cause some issues?
26 Nov 2018 23:59 #198209 by Delux
Not really sure what part you are referring to (going by my earlier contribution, I'm not really sure of anything to do with Jimnys, LOL!)
but if there is a plastic cover missing, the clutch cable could have corroded and be sticking. Not sure how that could be affected by the cars temperature though as corrosion would cause it to stick hot or cold.
27 Nov 2018 06:05 #198215 by Lambert
As i said earlier it's likely the oil causing this, I've had it with mine. The best and easiest thing is to change the oil to a known gl4 its very simple if a bit fiddly to do, there's guides in the wiki. Don't take the garages word for what they have used, change it and be sure. Oil is cheap compared to gearboxes.
27 Nov 2018 17:46 #198238 by Riccy
Replied by Riccy on topic Problem in gearbox or clutch?
Theres also the little rubber bushes on the stick linkage which make for hard gear changing when they are worn. really cheap thing to try ;-)
Time to create page: 0.271 seconds
