Battery terminal size
  • mickt
13 Nov 2018 15:00 #197632 by mickt
Battery terminal size was created by mickt
Is it me or are batteries for the Jimny a scarce item due to their small terminals? I have tried finding a Yussa battery on ebay and have typed in the search and up comes the list but when I fill in the car details non fit? So which makes fit? The one on the car is a 45Ah 330A cc and has been on the car since we got it ,6 years, so don't know how old it is. The battery went flat the other day and it turned out the daughter had been using the headlamps to watch the dogs last thing at night while they went about their business but with no engine running as it scares the dogs! Her mate and her tried to jump start it with new heavy duty leads to no avail so I ended up going to see it and tried using my Tiguan and again nothing. So I took the battery off as the dash board lights were very dull so reckoned it was as flat as could be and gave it a overnight recharge and lo and behold it fully charged and passed the load test using my load testing machine. I then went back to the car this time with my jump start kit and just used that to check start the car thinking that the starter motor had stuck. The engine burst straight into life so I then refitted her battery and all ok. I then checked the alternator and it was putting out 14.5v so hopfully all good, for now. But as its winter soon and knowing the battery has served its time I want to fit a good equally powerfull battery as is now fitted. Is there any particular supplier that can be contacted where I can get one?
13 Nov 2018 16:12 - 13 Nov 2018 16:15 #197639 by Max Headroom
Replied by Max Headroom on topic Battery terminal size
Personally I use Halfrauds but only because I've a Trade card and get a decent discount there.
I have also used Battery Megastore without problems. They deliver very quickly.
If you do it online just double check the +/- positions on the battery are in the correct position on the one you order, or you may end up with the leads from the car not reaching.
You probably know this, but the battery terminals have an adapter - a little cone that fits over them to make them fatter. Its a stupid idea; I've no idea why its done like this - prob something to do with Japanese specifications. When I got my Jimny those 'cones' were very worn and I couldn't tighten the therminals satisfactorily so acquired new ones.
I also used that red Liqui-Moly 3140 Battery terminal grease on the terminals to keep them from corroding - if you use that, shop around for a decent price - I think I got it on Amazon.
While youre on battery servicing procedures, it might be worth cleaning up the earth lead and greasing it with the Moly 3140 on reassembly
Last edit: 13 Nov 2018 16:15 by Max Headroom.
  • mickt
13 Nov 2018 19:14 #197643 by mickt
Replied by mickt on topic Battery terminal size
That is the crux of the matter then as my battery leads are suited to the original cone small size!
13 Nov 2018 21:20 - 13 Nov 2018 21:23 #197645 by Scimike
Replied by Scimike on topic Battery terminal size
Halfords ( I also have trade card, almost makes them cheap) sell replacement battery terminals. So if needed you can cut off the Jimny ones and replace them, you can then get any battery that will fit in the space...
But best exhaust direct battery replacements first.
I had to do this with my old land Rover as nothing was listed. I simple went into Halfords with a tape measure and got the largest battery that would fit in the space under the bonnet. You dont always have to do what the computer says :laugh:
Last edit: 13 Nov 2018 21:23 by Scimike.
  • jim
13 Nov 2018 21:23 #197646 by jim
Replied by jim on topic Battery terminal size
My recent Yuasa battery was from halfords. It came with the post adaptors which I removed. The product code was YBX5057
  • Venter
14 Nov 2018 17:17 - 14 Nov 2018 17:18 #197657 by Venter
Replied by Venter on topic Battery terminal size
Here are two options I've been considering for a while...
1) Yellow Top £130
2) Exide EP450 £168
Price aside, which would you folks go for?
Terminal layout on both is correct for the Jimny, although the Exide will need terminal clamp adaptors or a new clamp fitted.
Last edit: 14 Nov 2018 17:18 by Venter.
Time to create page: 0.105 seconds
