changing kingpin bearings - stupid problem, help appreciated
- muto
10 Sep 2018 17:02 #195846
by muto
changing kingpin bearings - stupid problem, help appreciated was created by muto
Started my project to change the kingpin bearings. Everything was fine until i tried to remove the old bearing outer races. The biltema 1" socket i bought today is going thru the race
. Tried to reposition it couple of times but when i take the hammer it just slips through.
Is there any mm sizes or special type of socket i need to use? Or do i just need to buy more sockets and try what works? Annoying that everything else was easy and now i have a problem like this.
Do not buy the Biltema 1" socket for this task
- muto
10 Sep 2018 17:42 #195848
by muto
Replied by muto on topic changing kingpin bearings - stupid problem, help appreciated
What kind of socket you use to change the bearing race? I see in some pics 24mm socket? 1" sockets seems to be not too easy to get here.
- mickt
10 Sep 2018 19:07 #195854
by mickt
Replied by mickt on topic changing kingpin bearings - stupid problem, help appreciated
Where.s here?
10 Sep 2018 19:27 #195857
Replied by mlines on topic changing kingpin bearings - stupid problem, help appreciated
Classic 1 inch socket, sounds like you got unlucky
- muto
10 Sep 2018 19:30 - 10 Sep 2018 19:31 #195858
by muto
Hi, Finland.
Probably need to go back to Biltema with ruler and pick up the next size available in mm. Anyone from Nordics done a kingpin bearing change with a Biltema tools?
Probably the current socket they sell in Biltema is just too modern and thin.
Last edit: 10 Sep 2018 19:31 by muto.
- mickt
10 Sep 2018 19:35 #195860
by mickt
Vernier calliper would be better!
