changing kingpin bearings - stupid problem, help appreciated
  • muto
  • Visitor
  • Visitor
11 Sep 2018 12:59 #195886 by muto
Biltema product number Art. 71-126 did the trick. Maybe would be useful to include this in the Wiki?
11 Sep 2018 14:57 #195887 by yakuza
Biltema (scandinavian halfords) product number 71-126 is a 24mm socket.
But this depends what the outer diameter of your socket is, and that is up to the manufacturer isn't it?
Acc to my SKF bearing catalogue the 30302 bearing should have a 36mm inner diameter for the hole supporting the race, 42mm outer.
  • muto
  • Visitor
  • Visitor
11 Sep 2018 15:42 #195888 by muto
Yes, the biltema 1" was too small but the 24mm "heavy duty" socket was perfect for the job. If i remember right, the 1" was 33,3mm and 24mm 33,8mm.
13 Sep 2018 14:28 #195975 by facade
I took mine out with a punch probably, or a chisel, never occurred to me to spend ages rooting around for a socket to hit. Bit of a swine working upwards too...
Time to create page: 0.208 seconds
