Emissions help
- Basketcase
19 Aug 2018 16:29 #195269
by Basketcase
Replied by Basketcase on topic Emissions help
That’s what I’m confused about there’s no engine light on. Should I try disconnecting the sensor to see if the car notices a fault and throws the light on? Is there anyway to fool it into fuelling differently without a remap?
19 Aug 2018 19:00 #195278
by facade
Replied by facade on topic Emissions help
The point that I'm trying to make is that if the sensor is giving the wrong reading, then the ecu merrily provides the wrong fuelling to match, all the time congratulating itself on getting it right, so it won't show any errors until the fuel trims max out before it can get the ok from the sensor.
I've had two cars fail emissions on running rich, both cured with a new generic 4 wire sensor, about £15 off eBay, neither put the eml on.
The one on the Jimny has been there at least 5 years now and just passed emissions this Saturday (0.01% CO, 5ppm HC, lambda 1.000)
I bet your lambda is below 1.
I'm not guaranteeing that a new sensor will cure it (as I'm at the other end of the interweb), but I think it will. For £15 why mess about?
The other possibility is a duff coolant sensor, so it thinks the engine is cold and is running open loop with a rich mixture anyway.
The live data will confirm what the coolant sensor says.
- Basketcase
19 Aug 2018 19:24 #195279
by Basketcase
The readings on 1st test were
CO. Actual 0.497 max .200
Hc. Actual 86 max. 200
Lambda actual 1.323. Max. 1.030
2nd rest
CO actual0.515
Hc actual.70
Lambda actual 1.177
Natural idle
CO actual 0.296 max 300 does this make any difference to your thoughts now about the sensors?
2nd rest
CO actual0.515
Hc actual.70
Lambda actual 1.177
Natural idle
19 Aug 2018 22:46 #195281
Back in the day if there was a risk of running rich we'd leave the air filter off but with all these dratted sensors I bet I couldn't do that these days.
:whistle:
Replied by helijohn on topic Emissions help
I wish I had such a comprehension of how the ECU runs our daily rides like you do.facade wrote: The one on the manifold before the catalyst. If the air cleaner was blocked I'd expect the eml ......
20 Aug 2018 08:50 #195285
by facade
It has been 30 years since I worked on fuel injection systems, and catalysts weren't in use, in fact we were only just moving from open loop systems, long lasting exhaust sensors were still new technology. (We were still working on the hot wire/film MAF sensors when I left)
Anyway, the high lambda indicates far too much air (lambda is [air/fuel]/14,7 so you are apparently running at 19:1 ) an exhaust leak anywhere would throw the lambda off as extra air will get in, manifold it will try and add fuel, post cat it will have good CO and HC readings..
The high HC indicate incomplete combustion, the HC is pretty much unburnt fuel. This could be a missfiring cylinder, caused by ignition fault, or over lean mixture (vacuum leak, possibly blocked injector or low fuel pressure), but I'd expect the CO to be low.
Normally high CO and high HC would indicate rich running, which is where we started, but that would make the lambda below 1.
I suppose rich enough to cause a missfire through plug fouling (clogged air cleaner, leaky injector, wrong information from sensors) would account for high CO and HC, but the high lambda seems wrong to me.
The only sensors are
water temp- open circuit here will run it permanently on choke giving high CO and HC but low lambda
Pre cat oxygen sensor- out of spec rich could give high CO and high HC but again low lambda, overlean would give high HC but low CO and a higher lambda.
Manifold Pressure sensor- a blocked pipe or failed sensor would completely throw the fuelling out causing rich or lean mixture.
Inlet air temperature (in airbox)- failure would affect mixture, as it uses air temperature, pressure and engine speed to work out the amount of air going in.
Cam & crank sensors - used to trigger the spark, measure engine speed and time the fuel injection, if one of these is intermittent it could cause a missfire, but the car wouldn't drive properly.
Fuel pressure affects the mixture, too low caused by filter blockage, pump failure or blocked regulator and it will run lean all the time, too high due to regulator stuck, or the vacuum pipe clogged and it runs rich.
As your mechanic suggested MAP sensor in the first place, have a look at it, I think it has a pipe with a small filter in, make sure that this is clear, and the hole into the inlet manifold.
Other than that, check for broke or split pipes, especially the pipe that feeds the vacuum hubs, and holes in the exhaust. I'd have a look for an exhaust leak around the manifold and down pipe, and check the EGR valve hasn't come off or something.
We've about reached the limit of what I can tell you now, Rhinoman knows a lot more specifics about Suzuki fuel injection than I do, I'd have just checked all the pipe work, and hoped a new pre-cat sensor would fix it
- Basketcase
21 Aug 2018 20:19 #195341
by Basketcase
That may have helped a lot as the vac pipes aren’t connected and the vac hubs have just been ‘locked’ in place on the shafts(as if they’ll stay like that off road) but the vac pipes under bonnet are not connected so I will just double up the pipes so it’s a loop on the ‘t’ piece and see if that corrects things:)
Time to create page: 0.105 seconds
