Emissions help
- Basketcase
18 Aug 2018 21:16 #195240
by Basketcase
Emissions help was created by Basketcase
Had the jimny at mot and it failed on all the emissions high. Mot man said it was running rich and said could be the map sensor...I have diag equipment at work what do I look for when I diag it for the map sensor to see if it’s working? Is there anything else I should look for that could cause the high emissions?
- MadsV
18 Aug 2018 23:01 - 18 Aug 2018 23:02 #195241
by MadsV
Replied by MadsV on topic Emissions help
Dont think any diagnostics will help you there. I guess you can measure ohm on the sensor, in the workshop manuals they often write how many ohm a working sensor should give.
But, it could just as well be the catalytic converter. I changed mine to a cheap ebay one and it was well inside the levels. Was the car driven and heated well? A cold engine will give off more, we usually let the car idle until hot and rev the engine to get it warm enough to pass the test
Last edit: 18 Aug 2018 23:02 by MadsV.
- Basketcase
19 Aug 2018 08:36 #195248
by Basketcase
Replied by Basketcase on topic Emissions help
Temp gauge was showing up to temp when I collected it about 20-30 mins after he tested it so I guess it was the right temp. I’ve not got the money to be throwing a cat at it or anything for that matter can just about afford to get 2 wheel bearings for it! The tester said it was running rich so it gonna work on that theory for now and see if I can get it normal first
19 Aug 2018 09:52 #195249
by facade
Replied by facade on topic Emissions help
Running rich is often the pre-cat exhaust sensor gone out of spec.
It could be a really blocked air cleaner, the way to tell (apart from examine it!) is look at the fuel trim values, if they are right down it is not enough air, if they are turned up than it is the sensor.
A new generic one is only about £15, you have to get the one with the right number of wires, and the plug off yours is crimped onto the new one with the supplied metal tubes as you cannot solder to the wire.
- Basketcase
19 Aug 2018 10:02 #195250
by Basketcase
Is that the sensor that is located in the cat itself? I’ve got the launch diag at work do you know of that could do the tests you need to do on it? Quite a long shot if anyone knows about it though
19 Aug 2018 15:32 #195263
by facade
The one on the manifold before the catalyst.
How it works is the ecu just guesses the fuelling by looking in a table called the "map" (called running "open loop") when you accelerate based upon engine speed and manifold pressure, it doesn't really matter if it gets this wrong, as they aren't testing it, people fiddle with this predefined fueling when they "remap" the ecu. If it knows the sensor is kaput (usually if the heater goes open circuit), the eml comes on, and it carries on guessing what the fuelling should be. It may even pass the emissions test in this mode.
When you are running at constant speed & load the precat sensor is used. It is a switch that changes state when the fuel/air ratio is correct. The ecu goes into a "closed loop" mode, where it trims the fuel back slightly until that sensor changes state, then quickly tweaks it the other way a bit, so the fueling goes very slightly lean-very slightly rich-very slightly lean for ever. If you look at the live data stream, the sensor switches from below 0.3V to above 0.6V and back again around once a second.
If the air cleaner was blocked I'd expect the eml to come on as it can't go closed loop if it can't reduce the fuel enough.
Holes in the exhaust before the catalyst pull in air and affect the measurement too, but you'd know if you had one.
If the sensor seems to be working, but has gone out of spec., then the ecu does a great job of controlling the fuel to the wrong value and you fail the emissions test.
The sensor after the catalyst is just there to check that the catalyst has done its job and converted all the carbon monoxide into carbon dioxide.
The following user(s) said Thank You: Basketcase
Time to create page: 0.090 seconds
