Lambda sensor question. (yes I know etc etc)
- NicBe
19 Aug 2018 07:21 - 19 Aug 2018 07:23 #195246
by NicBe
Replied by NicBe on topic Lambda sensor question. (yes I know etc etc)
I didn't think that an engine management light being on was a failure, I just received an advisory for mine, its all down to if it fails the emissions. I believe their is little difference to the sensors just the connectors and wires as they work on a potential difference. I have just bought a new and unwanted denso DOX 0113 for 20 squid for my front sensor. On some sites this is mentioned as being compatible to many vehicles including my Jimny, possibly due to coming with no connector just with heat shrink connectors. It also comes with a wiring color code if you are wiring it to anther manufacturers connector. Mines a denso so like for like. Will let you know what happens when I get around to fit it.
Last edit: 19 Aug 2018 07:23 by NicBe.
19 Aug 2018 10:12 - 19 Aug 2018 10:16 #195251
by facade
If you look in section 8,2 of the Testers manual www.gov.uk/government/publications/mot-i...3-4-5-and-7-vehicles
you find under defects
So it should be a fail. It is down to the indication of a malfunction meaning that Something is Not Right and this could be an environmental problem.....
As to which sensor, there are only 2 types as far as I know, and one with the right number of wires will work, mine is a generic one, and has been perfect on emissions for 5 or 6 years now.
You have to join the wires to your old wire & plug (don't cut them too close to the plug in case you want to change it again)
Replied by facade on topic Lambda sensor question. (yes I know etc etc)
NicBe wrote: I didn't think that an engine management light being on was a failure, I just received an advisory for mine, its all down to if it fails the emissions.
h. Engine MIL inoperative or indicating a malfunction Major
Last edit: 19 Aug 2018 10:16 by facade.
- NicBe
23 Aug 2018 11:30 #195380
by NicBe
Ah see you are right, looks like they changed in May explains why mine was just an advisory. Just as well that the sensor worked, Dox 0113, for a 2006 vvt front sensor.
Time to create page: 0.075 seconds
