Lambda sensor question. (yes I know etc etc)
  • mattsccm
15 Aug 2018 10:24 #195139 by mattsccm
The Jim has failed the MOT as the engine management light was on. Code check tells us that its the pre cat one. But how the hell do I know what to buy? There appear to be millions of different versions out there. Online compatibility checks asked for the model of engine. Now the the********** would I know that. Its green, that's what matter! Wife bought it new and only found out last week that it was RWD in 2WD.
V5 says 1328cc from 2004. Engine number begins with M13A
Prices seem to run from 30 quid to 10 times that. I want a cheap fix. I'd take the bloody bulb out if it was easy.
My Land Rover is so much easier.
Your guidance please.
  • mattsccm
15 Aug 2018 10:43 #195141 by mattsccm
  • mickt
15 Aug 2018 13:57 #195145 by mickt
That shows lots of different makes. Have you tried your local motor factors? Car reg should be all that is required to get the correct one with the info above and pre cat sensor as the part required.
  • mattsccm
15 Aug 2018 16:25 #195147 by mattsccm
Replied by mattsccm on topic Lambda sensor question. (yes I know etc etc)
Ha, you would think so. They offer me all sorts hence me looking at that list above. Dozens out there but I have no idea which to chose of all those labelled as correct for the car hence the reason for asking.
15 Aug 2018 16:31 #195148 by Lambert
Ask Martin the admin Mlines of this parish he will need a registration number and can cross reference from there.
15 Aug 2018 17:19 #195151 by Riccy
Yep Martin is your man (see the bigjimny shop).
Yours is not a VVT at that year so M13a is the engine code.
Time to create page: 0.104 seconds
