Seemingly unique 4wd issue
  • TFB
10 Aug 2018 23:30 #195023 by TFB
Replied by TFB on topic Seemingly unique 4wd issue
Hi Busta, Thanks for the input, it will be interesting to see if anybody has any further advice on this. Plus, the more technical it gets, the more dubious I am to take it to a mechanic here as I get the feeling they won't have a clue about this kind of thing. I'm inclined to do whatever needs doing myself though. I just need it sorted soon, these parrots aren't going to save themselves, haha.
11 Aug 2018 00:14 - 11 Aug 2018 02:06 #195024 by zukebob
Replied by zukebob on topic Seemingly unique 4wd issue
I'm not sure from your comments but it sounds as though you are expecting the hubs to engage by putting a jumper at the vacuum switch connector. If I'm correct and that is what you're thinking, it will only allow the transfer case to engage. The hubs would remain open unless you have vacuum.
To clarify:
IF you have manually applied vacuum and are sure that the hubs are currently engaged
AND you shorted the leads to the vacuum switch and engaged the transfer case by pushing the button
then you should have 4WD. If this is what you have done and still don't have 4WD, I would agree with Busta.
Edit:
As far as this goes
side note: when directly under the middle of the car I took the rubber tubes off the vacuum system and there is definitely no leak on either tube going in the direction of the wheels. But going the opposite way, to the solenoids and valves, there was almost a free flow of air through both tubes. The car was off at the time, is this normal?
I'm not sure but don't think so and this would still make me suspect that you have a leak. As you inspect the system, the one place that is hard to determine is the vacuum tank. There is a hose that leads to the tank that is mounted inside the fender.
Last edit: 11 Aug 2018 02:06 by zukebob.
  • TFB
11 Aug 2018 18:33 - 12 Aug 2018 20:25 #195031 by TFB
Hi Zukebob,
Thanks for the help, I got back on the car today and found the vacuum tank, from the tank to the solenoids there's no leak, and from the manifold to the solenoids there's no leak either. So it just seems that its from the wheels to the solenoids that they both seem to have a free flow of air. I'm not quite sure how the solenoids work but is it something to do with the valve/filter thing on the back of them? I still don't know if this is a good or bad thing.
I will also note that if I sit in the drivers seat and press the 4WD button, as it blinks away for its 10 or 15 seconds, every couple of seconds theres a tick that sounds like a relay (a switch in the controller?) from under the dash every two or three seconds. sounds like its going on....off....on....off...on...off then it stops as the blinking stops.
With regard to your claification, yes that is exactly what happened. However, despite the hubs being locked manually by sucking the tubes, and shorting the vacuum switch with a small bit of wire, when I went to engage the transfer case by pushing the button, the exact same thing happened with the flashing 4WD light and clicking sound, which then both went off, leaving me as though I had never pushed the button, i.e. still in 2WD
I'm not sure how to do the quote system so apologies for the incoherence of this message, but with regard to the first thing you said, No I was only expecting the transfer case to engage. So, if I were to put 12v to the controller to force the transfer case to engage the front drive shaft where would this leave me? would the car know (or display) that it was in 4WD? would it try and come out of it if the controller is gone? At this point I'm guessing that even if this works this a really just a temporary solution and the car needs a new controller. However, it would be nice to know for sure if this is what it needs as I work for an NGO and money is tight.
Last edit: 12 Aug 2018 20:25 by TFB. Reason: changed the words now in bold for clarity
12 Aug 2018 02:51 - 12 Aug 2018 03:02 #195041 by zukebob
Based on what you say, your current issue shouldn't be vacuum related. With the hubs manually engaged and a jumper at the vacuum sensor switch, you should have 4WD and everything should appear normal (no flashing 4WD light). In my mind that would narrow it down to the 4WD controller, the transfer control module or the 4WD switches on the transfer case.
I will send you a private message with some information that may help, if you want to (are able to) fix this yourself.
If a DIY fix is beyond what you have available in tools or facilities, hopefully it will help a local mechanic.
After all, we need to keep them parrots alive.
Edit: I can't attach a file in the PM so I will attach it here. It is the section of the service manual for the push button transfer with the electrical diagram attached.
Last edit: 12 Aug 2018 03:02 by zukebob.
12 Aug 2018 03:17 #195042 by zukebob
Also, so that we don't embarrass ourselves, check fuse 88.
  • TFB
12 Aug 2018 20:14 #195061 by TFB
Thanks for sending that information Zukebob, at least it seems we are able to narrow it down if nothing else. I've had a quick look at the file and I think this may be a bit beyond me. However I'm sure it will come in handy to whomever it gets passed on to, so thank you for all your help.
Can you give me a quick guide to where fuse 88 is please. I have no cover on the fuse box under the dash, which is where I assume the legend would be. That is, unless its in the box under the hood?
Time to create page: 0.094 seconds
