Seemingly unique 4wd issue
- TFB
8 years 3 months ago - 8 years 3 months ago #194999
by TFB
Seemingly unique 4wd issue was created by TFB
Hi All,
I have spent the last two days trawling the forum and the internet in general, but I cant seem to find anything that quite matches my symptoms. I've read the guides to hubs and transmission from this site and I thought I was starting to get my head round the problem, but unfortunately I cannot seem to fix the issue. So without much more rambling from myself here is what I know:
2013 1.3l Suzuki Jimny, 85,000 kms on the clock, push button 4WD system
Never had any issues before with the 4WD but a few days ago I went to engage it and nothing happened, the green 4WD light blinked slowly for 10 seconds or so, but no clunking noise as I would normally hear then the light went out. If I tried this two more times in a row both the Green 4WD and the Orange low range light would both come on and blink quickly and not go out until the car was turned off and on again.
So, many hours searching the forums would suggest an issue with the vacuum hubs. So, I visually checked the whole system and cannot seem to find any breaks or tears or corrosion of the metal pipes, the system seems okay to my untrained eye (side note: when directly under the middle of the car I took the rubber tubes off the vacuum system and there is definitely no leak on either tube going in the direction of the wheels. But going the opposite way, to the solenoids and valves, there was almost a free flow of air through both tubes. The car was off at the time, is this normal?). Anyway, I found some useful information about manually sucking the hubs, so I did that, and the hubs quite easily engaged. I understand that I then needed to fool the controller so I shorted the sensor cable that is attached to the side of the box that holds the solenoids and runs to a sensor under this assembly (small rounded cable clip that has a black and a grey/white cable). I did this by sicking a small wire into each of the female connector sockets that would effectively join them together.
My understanding is this would then trick the controller into thinking that the vacuum system worked and the car would then celebrate by staying in 4WD for me.
However, this has not happened. No change at all really. Its good to know I can lock and unlock my hubs this way but, I'm finding the front propshaft wont engage/lock. I should add at this point that I am in the middle of the jungle in Costa Rica and I'm on my own, so checking things like the vacuum system isn't going great, but I've tried to press the 4WD button then jump under the car to see if the front drive shaft locks, but noting, it spins freely.
Now I may have misunderstood everything I've read (and I am pretty much a beginner at this), but I think there is a problem in the transmission where the front propshaft isn't engaging/locking, rather than a problem with the vacuum. But I could be wrong. You guys have already been great, just by all your comments on this forum, and I've been a browser ever since getting the Jimny a year ago and never had to start my own thread to solve a problem, until now. My work as a field biologist relies on this car being able to engage 4WD, so I'm hoping I can get this solved quickly.
All my rambling done with, any ideas/suggestions. Thanks in advance for any help.
Last edit: 8 years 3 months ago by TFB. Reason: added side note about tubes
- Thank you received: 2004
8 years 3 months ago #195003
Replied by Lambert on topic Seemingly unique 4wd issue
Id be inclined to look at the solenoid valve block in the engine bay just below the battery tray. It has a simple filter to keep the bigger rocks out but it can clog. It's also possible that one or more of the solenoids are sticking, a bit of a tap and a some wd40 can be enough to free them off.
- TFB
8 years 3 months ago #195004
by TFB
Replied by TFB on topic Seemingly unique 4wd issue
Hi Lambert, Thanks for the advice. I've cleaned the pretty crude filter out and there were no problems there, I also added an edit to my initial post possibly as you were typing your response, but I note that there was a free flow of air back up the pipes (from under the car and as opposed to the vacuum in the direction of the wheels). I dont know if this is good or bad. and now I've given the solenoids a bit of a tap and a spray as you suggested, but nothing has changed, same situation I'm afraid.
8 years 3 months ago #195008
Ok. Is the control wires to the transfer box intact? They are fairly low down on the transfer box and quite easy to catch on vegetation and rocks?
- TFB
8 years 3 months ago #195012
by TFB
Yup, all the wires are attached and seem in good condition down there.
8 years 3 months ago #195019
by Busta
Replied by Busta on topic Seemingly unique 4wd issue
Your issue is definitely with either the transfer box or 4wd control unit and not the vacuum hubs. Beyond that I can't really help. I'm sure there is a way to engage 4wd in the transfer case by applying 12v to certain wires, but having never had a Jimny with the electric transfer case I can't tell you exactly how.
Time to create page: 0.092 seconds
