radiator removal
  • helijohn
03 Aug 2018 00:11 #194805 by helijohn
Replied by helijohn on topic radiator removal
What about the shroud? I have always found it to be a pain and frankly leave it off or cut it down to just give a top section and I can say it made no difference to the cooling
03 Aug 2018 09:02 #194809 by yakuza
Replied by yakuza on topic radiator removal
I never touched the aircon so it is no issue as ar as i remember.
Think i either unscrewed the fan and took it out with the radiator and shroud, or left shroud in there together with the fan. I cannot remember having any
problems.
I did not have to cut anything. But i have seen others do it.
Dunno why.
03 Aug 2018 09:04 #194810 by yakuza
maverick wrote: simple, we even took off my radiator when off-road to make replacing the Fan Belt easy!!
When my radiator was out, i made sure i had the belts ready and changed them when access was easy.
  • littletriple
03 Aug 2018 17:25 #194815 by littletriple
Replied by littletriple on topic radiator removal
Thanks all, it doesn't sound like a pain. I had a brief look today & it seems the engine rad can be released from the aircon exchanger & the shroud & lifted out. We'll see... :whistle:
  • NicBe
05 Aug 2018 12:58 - 05 Aug 2018 12:59 #194840 by NicBe
Replied by NicBe on topic radiator removal
Just removed mine today,
Drain fluid
Unbolt fan cowling 3 Bottom 2 top, remove bolts completely or they will fowl the fan when you lift it out
Remove top hose
Remove bottom hose
Unbolt rad, 2 10mm bolts at top sides of rad
Move cowl as far forward to engine as pos
Lift rad out, hand spin the fan as you lift to allow the bottom outlet space you'll see.
Takes longer to drain than remove
Last edit: 05 Aug 2018 12:59 by NicBe.
06 Aug 2018 13:02 #194864 by Busta
Replied by Busta on topic radiator removal
Helijohn, the shroud massively increases the efficiency of the fan. It might be fine without the shroud for normal pootling about but if you work it hard on a hot day there's a much higher chance it will overheat.
Time to create page: 0.215 seconds
