radiator removal
- littletriple
01 Aug 2018 19:56 #194770
by littletriple
radiator removal was created by littletriple
Hi,
I may need to take out my rad, how easy is it to remove? Is it straight forward or is there a lot of other stuff that needs to come out first? Car is a 2007 manual with aircon.
cheers,
Martin.
cheers,
Martin.
01 Aug 2018 21:39 #194772
Replied by yakuza on topic radiator removal
It is a straight forward and fairly easy job. the only hassle is the liquid and the fan shroud, I cannot remember meeting any obstacles.
- littletriple
02 Aug 2018 07:31 #194778
by littletriple
Replied by littletriple on topic radiator removal
that sounds easy enough. I did thought I read somewhere that you have to do something with the aircon rad to allow enough space to lift the main rad out?
So just drain down the rad, undo the obvious fixings/hoses & it should lift/jiggle out leaving the fan shroud & aircon rad in the car?
- Thank you received: 923
02 Aug 2018 08:20 #194779
Replied by X8GGY on topic radiator removal
I've replaced the radiators on both my current Jimnys, but neither has air-con, so I can't offer any assistance
But as Yakuza says, it's dead easy on a non-air-con model?
- Thank you received: 115
02 Aug 2018 15:25 #194788
by maverick
Jalapeño, IISY?
Replied by maverick on topic radiator removal
simple, we even took off my radiator when off-road to make replacing the Fan Belt easy!!
Jalapeño, IISY?
- NicBe
02 Aug 2018 17:50 #194793
by NicBe
Replied by NicBe on topic radiator removal
It's dead easy with aircon, the aircon rad is mounted on the same bracket, but on different mounts so no need to remove air con or fan
Time to create page: 0.222 seconds
