Killing the low tyre pressure warning light.
03 Jun 2018 20:59 #193178 by Thordur
Since my 2015 Jimny went on 35" tyres the low pressure warning light is constantly on. The sensors were moved to the new wheels but since I usually keep the pressure at 20 psi (or less) the quickest way to get rid of the light is to get the speedo cluster out and cut the wire leading to the bulb. Does anyone have a recent diagram that shows which wire leads to this bulb?
Regards from Reykjavik
Thordur
  • OlaGB
03 Jun 2018 21:05 #193179 by OlaGB
Sorry for not being able to help you, but that car sure caught my interest!
Would love to read about it, and see more pictures of it! Must be motor converted as well i guess?
03 Jun 2018 23:14 #193184 by Jezz
Can you not just take the bulb out ?
It's been fettled just a tad.
03 Jun 2018 23:56 #193185 by Thordur
Of course I could, but it seems too much trouble totally dismantling the instrument cluster, pulling the hands of the dials, etc. and risking messing something up.
04 Jun 2018 04:03 #193186 by Lambert
I thought that the bulbs were surface mount from the back if the cluster, no need to split the casing?
04 Jun 2018 08:25 #193191 by Jezz
You say in your first post, You are going to remove the cluster to cut the wire. When you remove the cluster, You will see that the bulbs just clip in on a bayonet type fitting. Just remove the relevant bulb.
Time to create page: 0.170 seconds
