Noises - Checklist
04 Jun 2018 12:57 #193199
by furo
Replied by furo on topic Noises - Checklist
Thanks! What do you mean by nip up - tighten them?
06 Jun 2018 09:01 #193244
by furo
Hi kirkynut - I have tightened up the radius arm bolts and each nut did a few full rotations, but the noise is still there. It does seem to be coming from them. What do you suggest I do next? If the holes are elongated how do I fix that, will they have to be welded? Thanks!
10 Jun 2018 18:41 #193355
by furo
I have removed the radius arm guards and thankfully none of the holes are elongated. I put the bolts back in without the guards and went for a test drive, but unfortunately the noises are still there. I also triple checked the transfer box mounts and checked the shock bolts. Any suggestions for what I should check next?
Time to create page: 0.083 seconds
