Noises - Checklist
02 Jun 2018 15:54 - 02 Jun 2018 15:55 #193151
by furo
Noises - Checklist was created by furo
Hello,
I was wondering if you guys could help me out as I investigate some noises my Jimny has been making. Over the past 3 years it has developed a couple of different noises - a low pitched clunk and a higher pitched click that seem to come from underneath the centre of the car, as well as an occasional squeaking sound. I tend to hear them most when it flexes coming out of my underground parking or when I go over speed bumps, but they can happen at any time. Details of my vehicle are in my signature.
So far I have inspected the two transfer case mounts and can't find an obvious problem with them (although they are coated in dinitrol). Movement in the transfer case is minimal. I have replaced the rear engine mount, which was knackered, but that has not made a difference to the noises. I have manhandled the props to see if there is any movement but there is not. I have tried to move my radius arm guards by hand and they don't seem loose.
Can anyone suggest an alternative cause for these noises? What should I check next? Also - I'm not confident that I have checked the transfer box mounts/UJs thoroughly - what exactly should I be doing?
Thanks in advance!
Thanks in advance!
Last edit: 02 Jun 2018 15:55 by furo.
02 Jun 2018 16:15 - 02 Jun 2018 16:16 #193153
Replied by Riccy on topic Noises - Checklist
Forgot to say... you can't feel the play in the prop UJ when its on the car. take it off and check for play is the only way :laugh:
Last edit: 02 Jun 2018 16:16 by Riccy.
03 Jun 2018 15:40 #193169
Replied by Daniel30 on topic Noises - Checklist
Have you checked all the exhaust fittings, hangers etc?
03 Jun 2018 15:42 #193170
Not much room around the back for the back box and the rubbers stretch so even if they don't look bad there might be to much movement in them.
04 Jun 2018 11:16 #193195
by furo
Replied by furo on topic Noises - Checklist
Riccy - ah right thanks! I'm afraid taking it off the car is not in my comfort zone lol
Daniel30 - thanks! I have a custom stainless exhaust so I assumed it was fine (only a year old) but I will check it out
04 Jun 2018 12:38 #193197
by kirkynut
Replied by kirkynut on topic Noises - Checklist
Nip up the radius arm mount bolts. You cannot put enough force on them to test them by hand and they can move in their holes, causing the holes to elongate.
Time to create page: 0.090 seconds
