Settting differential backlash, side adjuster tension?
- OlaGB
12 May 2018 09:45 #192615
by OlaGB
Settting differential backlash, side adjuster tension? was created by OlaGB
Trying to read up on the backlash adjusting, preparing for installing a air locker in my rear diff.
When i read the manual, i have a hard time understanding how to tension the side adjusters correctly.
I can see that i have to set the carriers down with 15nm, and tighten the side adjusters until they touch the bearings to "prevent from inclining"..
The way i read this, is to just "hand tighten" the side adjusters to get rid of any play on the bearings.
Then set backlash to 0.10-0.20 mm using both side gears, while "obtaining preload on differetial side bearing".
The amount of preload is never mentioned, this is where i`m lost.
All i can find, is to measure the amount of force needed to turn the incoming bevel gear with a torque measure, after tightening the cariers fully down. Are they really basing the preload, on the total amount of friction in the differential??
In some youtube video`s ive seen on the topic for other makes, they say things like "hand tight + 1/4 turn on one of the side adjusters" or similar.. Which is alot easier to relate to.
I`m not experienced on setting up differentials, and it might be the language barrier putting me off a bit, so i would be very happy for someone explaining how to do this right..
12 May 2018 16:31 #192625
Replied by Riccy on topic Settting differential backlash, side adjuster tension?
Its not that difficult (he says!)...
You need only one special tool which is something like this:
www.machinemart.co.uk/p/cm220-dial-test-indicator/
This is a dial indicator which can be used to measure small amounts of in/out movement accurately.
You then need to follow the instructions in the workshop manual:
The specified amount of backlash is 0.1 - 0.2mm. use the dial indicator to measure as in the instructions and its pretty easy.
Finally make sure to do the chalk test on the gear teeth to make sure the wear locations are the same as before disassembly. If out then adjust in/out on each side at the same time to bring it back to the original position.
12 May 2018 16:37 #192626
Ah, re-read and im on the wrong subject.
Preload. It is set by the backlash and a torque wrench:
- OlaGB
12 May 2018 17:26 #192628
by OlaGB
Yes thats the only thing ive found, but who has a 0.2nm wrench?
Seriously, you dont know what friction you are measuring by this method, only the total amount of friction.. Could just as well be the pinion gear bearings that has all the friction without me knowing. Thats why i dont understand that this is a good way to do it.
Well that, and the fact that i need a 0.2nm wrench to do it
Replied by OlaGB on topic Settting differential backlash, side adjuster tension?
Riccy wrote: Ah, re-read and im on the wrong subject.
12 May 2018 17:35 #192629
0.2nm, yes I do
Im an electrician and we have them as a screwdriver for setting torque on terminals.
not that expensive...
uk.farnell.com/c/tools-production-suppli...n-m=0.2n-m-to-1.5n-m
though mine is a VDE rated one which is a lot more!
I agree that its not an ideal way to do it, but thats what we have to work with :laugh:
16 May 2018 10:20 - 16 May 2018 10:22 #192746
by facade
Replied by facade on topic Settting differential backlash, side adjuster tension?
No eBay APP ID and/or Cert ID defined in Kunena configurationUse a spring balance like this one
You set the pinion preload first with the crush spacer, then check the side bearings.
You want the maximum reading off the scale- the force to start it moving, not the force to keep it going round, which will be less.
You can calibrate the balance first with a small bag of sugar or something, checked against scales you know are right.
Last edit: 16 May 2018 10:22 by facade.
Time to create page: 0.106 seconds
