Boot panel replacement
  • Jim Jimny
24 Jan 2018 09:57 #188796 by Jim Jimny
Boot panel replacement was created by Jim Jimny
Hi
I want to replace the boot floor, I've registered my Jimny with DVLA as a 2 seater as I use it as a van and to cart my dogs around in.
The question I want to ask is because it has no rear seat belts and the Jimny has a chassis ie the body isn't structural, does the panel have to be welded in place, can it not be bonded?, I have another 4x4 a cruiser, I had to do a small repair in the boot and what I was advised to do was to bond it and pop rivet it in place, in effect the pop rivets hold it in place while the bonding agent goes off.
24 Jan 2018 11:11 #188799 by mlines
Replied by mlines on topic Boot panel replacement
I understood that patches that are not near the body mount points or seat-belt points can be bonded.
Anything else needs welding
  • MadsV
24 Jan 2018 13:58 #188806 by MadsV
Replied by MadsV on topic Re:Boot panel replacement
The panel it self is not a part of the seat belt bolts, its underneat. I replaced my panel and used only bonding and a couple of screws.
Its bolted to this bracket under
24 Jan 2018 14:15 #188807 by mlines
MadsV wrote: The panel it self is not a part of the seat belt bolts, its underneat. I replaced my panel and used only bonding and a couple of screws.
That is true but try telling it to an MOT man
  • MadsV
24 Jan 2018 17:53 #188814 by MadsV
We do MOT at our shop, no one had any comments to this as it does not do any harm to the frame and structure. I change body panels all the time and do not consider this any problem, but this is not the UK and there is always some a-holes doing MOTs. :)
  • Jim Jimny
24 Jan 2018 18:41 #188815 by Jim Jimny
Replied by Jim Jimny on topic Re:Boot panel replacement
Seat belt mounting points shouldn't be an issue for me as it is registered as a 2 seater and the rear belts have been removed.
Time to create page: 0.090 seconds
