Tyres - again!
22 Nov 2017 09:10 #186585
by kirkynut
Replied by kirkynut on topic Tyres - again!
215/75/15 & 2" lift work well. You don't want to go too big or you'll overheat your automatic transmission fluid in no time on hills etc. A bigger cooler for it might be useful.
Rhino Ray has experience with Auto Jimnys. Give him a call.
The following user(s) said Thank You: Barry
23 Nov 2017 09:55 - 23 Nov 2017 09:56 #186627
Replied by yakuza on topic Tyres - again!
I got 235/75-15 with 2" lift.
no cutting and only insignificant rubbing (in my opinion) but my car do not have the original mud flaps.
Power loss with those tires is however significant. Gearing as well. It is all show show and less go.
For my own offroading i like to float on top with very low tire pressure and very low rev on the engine, instead of digging down to get traction so i prefer to go wide.
M16a engine swap corrected most of the power loss and the low end torque gained from 1.6 engine also helped a lot with the gearing as i do not have to use so much rpm to get it going offroad. But i will change the low range gearing in the transfer box some day.
For any serious offroading with 235 you would however need to do something to the gearing even though you have an auto gearbox.
With the 215 tires most problems with the gearing and power loss is not very noticeable and you could spend the money on a diff lock instead of a lift.
Last edit: 23 Nov 2017 09:56 by yakuza.
- bowji john
23 Nov 2017 19:32 #186646
by bowji john
Replied by bowji john on topic Tyres - again!
At the risk of hijacking this thread ...
Can anyone tell me the total height of 215 75 15 BFG Muds from road to top of Tire
Thanks
j
Thanks
j
- Barry
23 Nov 2017 20:00 #186647
by Barry
Replied by Barry on topic Tyres - again!
27.7" (704mm)
Always keep this website in your favourites, and it allows you to compare two tyres at once:
www.tyresave.co.uk/tyre-size-calculator/
- bowji john
23 Nov 2017 20:05 #186648
by bowji john
Thanks for the info and the website Barry
Much obliged
J
Much obliged
J
- Thank you received: 706
23 Nov 2017 20:07 #186649
Replied by jackonlyjack on topic Tyres - again!
A new tyre will be around 700mm-705mm
A retread/remould could be around 10 - 20mm taller
will depend on tread pattern AT or MT
Jack
Jack
Time to create page: 0.091 seconds
