Tyres - again!
  • Barry
21 Nov 2017 17:40 #186559 by Barry
Tyres - again! was created by Barry
Sorry, I know this may have been done to death...
Buying an auto Jimny (2013), and I really can't make up my mind. Do I go for:
215/75r15 with 30mm spacers and 2" lift
or
235/75 (no spacers) 2" lift
I'd rather not cut anything about, but will if I have to. But I do want it to look 'right'. All comments most welcome.
21 Nov 2017 19:43 #186561 by Lambert
Replied by Lambert on topic Tyres - again!
You say you want it to look right, so you will probably not like me saying that the narrower the tyre on a Jimny the better they work in the typical off road conditions we have in the UK. Also spacers are not good for wheel bearing longevity.
The following user(s) said Thank You: Barry
  • 1066Boy
21 Nov 2017 19:49 - 21 Nov 2017 19:51 #186562 by 1066Boy
Replied by 1066Boy on topic Tyres - again!
215/75/15 with no spacers. :) lift optional. :)
Last edit: 21 Nov 2017 19:51 by 1066Boy.
21 Nov 2017 19:53 #186563 by HUN
Replied by HUN on topic Tyres - again!
Hi Barry,
As far as I know you will need to change the gear ratio in the transfer box in order to have enough torque/power for those tyres. Personally I would go for 195/80R15 with 2" lift (I have now) as it does not affect the performance so seriously as those 235/75 tyres would. I know also the golden rule says if you go up you must go wider but it would put more force on the kingpin bearings so I rather drive more carefully than before (I have no spacers). Others may disagree so keep asking!
(sorry for my crap grammar ;) )
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
  • 1066Boy
21 Nov 2017 19:55 #186564 by 1066Boy
215/75/15 fine on standard gearing, it is the max though in my opinion.
22 Nov 2017 08:59 #186583 by Busta
Replied by Busta on topic Tyres - again!
Everyone's look is different, but 215/75r15 with no lift and no spacers looks right to me :) Spacers look chavy and the lift is unnecessary.
The following user(s) said Thank You: 1066Boy, Barry
Time to create page: 0.131 seconds
