Offside front body mount coroded
14 Nov 2017 18:08 #186255 by jackonlyjack
The part with hole is part of the front panel very expensive to replace
14 Nov 2017 18:30 - 14 Nov 2017 18:34 #186256 by weecorey
That part is £217 +p&p, well it was that price last year anyway. It's a job to replace as it's spot welded to the inner wings.
I'm definitely going to look into making up replacements of these mount surroundings. If the mount it's self is 100% then fitting a new surround would be handy enough. I'm thinking 2 half that fit perfectly over the original and would be easily tacked on. As I've said its my opinion that this part does nothing but hold water and rust but if it's a common problem so it would be good to have a straight forward fix.
Last edit: 14 Nov 2017 18:34 by weecorey.
  • petejones69
14 Nov 2017 18:40 #186257 by petejones69
Replied by petejones69 on topic Offside front body mount coroded
Thanks both, sounds like a plan to have an easy replacement/fix - I'd buy a pair.
  • mickt
14 Nov 2017 19:16 #186258 by mickt
Replied by mickt on topic Offside front body mount coroded
Take the headlight out and check there as it rots bad there too and also check the other side while you are on as they are both prone to rot. Also extends in the engine bay behind the steering box and in the same position on the nearside. It is the front tubs crossmember.
Time to create page: 0.091 seconds
