26spline front arb?
28 Dec 2017 12:59 #187832
Replied by jackonlyjack on topic Re:26spline front arb?
The 26 spline side gears are to use with heavy duty shafts
standard shafts have 22 splines
You can use rear diff side gears in the front as these have 26 splines
Hope this helps in some way
Jack
Jack
- Ronstan
28 Dec 2017 14:00 #187835
by Ronstan
Replied by Ronstan on topic Re:26spline front arb?
Yes, so it's possible to fit rear side gears into front diff and that applies to orginal parts.
The question was about ARB diff locker.
I am aware I can buy HD 22 spline shafts but I would rather prefer 26 ones. Especially with difflock.
- TomDK
28 Dec 2017 20:35 #187853
by TomDK
Replied by TomDK on topic Re:26spline front arb?
I think you guys are misunderstanding eachother a bit.
There is no 26 spline front locker made for the Jimny front axle by ARB. The only way of doing this is by using side gears from ARB rear locker in the front locker as they fit.
This just to clarify how it's done. When it comes to warranty it's up to the retailer. Probably where you got the locker.
- Ronstan
29 Dec 2017 03:42 #187860
by Ronstan
Thanks! That's the answer I was looking for
TomDK wrote: ...The only way of doing this is by using side gears from ARB rear locker in the front locker as they fit. ...
Time to create page: 0.157 seconds
