26spline front arb?
25 Oct 2017 07:21 #185496 by orisuli
26spline front arb? was created by orisuli
There is any front locker with 26 spline side gears?
I bought buy mistake and rd208... and find out its the right one for the front.
Is there any option to put it in high pinion third member ?
Or just replace it to rd206 ? And if so whats the part number for 26 spline side gears?
Sent from my SM-G900F using Tapatalk
25 Oct 2017 08:15 #185497 by zukebob
Replied by zukebob on topic 26spline front arb?
You need to use the rd206. If you are in the UK, Jimnybits sells the 26 spline gears.
25 Oct 2017 11:33 #185503 by orisuli
Replied by orisuli on topic Re:26spline front arb?
Thanks!
There is no arb part number so i can keep my warranty on the locker?
25 Oct 2017 23:54 #185522 by zukebob
Replied by zukebob on topic Re:26spline front arb?
I'm not sure if you are asking about the part number for the gear set. If you are, it is a 6 piece gear set, part number 728JA12. As far as the warranty goes, I'm not sure what effect a change would cause. You would need to read the terms in the warranty that came with the locker.
26 Oct 2017 06:25 #185524 by Riccy
Replied by Riccy on topic Re:26spline front arb?
Trailgear make 22 spline HD shafts, which is what i use with my ARBs (rd 207 and rd 208 i think). Might be an easier and cheaper option than changing the side gears.
Jimnybits do genuine ARB side gears as well as generic ones, so genuine should maintain the warranty (but are pricey)
  • Ronstan
28 Dec 2017 12:13 - 28 Dec 2017 12:19 #187830 by Ronstan
Replied by Ronstan on topic Re:26spline front arb?
Can you clarify what is the story with the side gears?
If I want to have front ARB locker (RD206/207) with 26 spline I need to get side gears (728JA12) and fit them into the locker instead the original ones? Is that correct?
When I checked this 728JA12 on website it says that it's for RD208, so will it fit to RD206/207 as well?
Last edit: 28 Dec 2017 12:19 by Ronstan.
Time to create page: 0.317 seconds
