4wd vacuum system issues
- Russ6334
23 Oct 2017 06:23 #185439
by Russ6334
Replied by Russ6334 on topic Re:RE: 4wd vacuum system issues
So if it’s held by magnets what is it’s resting position because every time I take mine off they are in the locked position (4wd) but I don’t have 4wd when I engage it and test on mud.
- Russ6334
23 Oct 2017 18:00 #185460
by Russ6334
Well I stripped the hubs down today after replacing most of the vacuum hoses to no avail.
Note to anyone with similar issues! Don’t bother trying to fix the vacuum system it’s so labour intensive!
I paid £15 for a metre of nylon bar turn it down on the lathe to 12mm with a wider end like a bolt that was flush with the hub. Put it inside like the rubber Bush mentioned by another thread and hey presto now have 4wd again.
This job including lathe work took about an hour. Messing around with the vacuum system and not succeeding took 4!!!
- mickt
23 Oct 2017 18:34 #185462
by mickt
Replied by mickt on topic Re:RE: 4wd vacuum system issues
Time well spent as you now know how the system works!
24 Oct 2017 00:57 #185475
by Keithy
Replied by Keithy on topic Re:RE: 4wd vacuum system issues
Sadly I believe you are in error with the statement that Russ understands how the system works.....he simply performed the final act of the system manually......the Wiki crew here have put a lot of time and effort into documenting Jimny owners common issues and have done a great job imho so maybe my lifelong assumption that everyone else knows exactly what I know/understand will need to be finally addressed.mickt wrote: Time well spent as you now know how the system works!
- Russ6334
24 Oct 2017 06:26 #185477
by Russ6334
Whoa this isn’t face book!
Im not slating anyone’s opinion!!!
I’m just saying having spent hours working on it to no avail it’s easier to fix the hubs! I understand the system but the parts are rediculously expensive and fixing the hubs cost me £15!
24 Oct 2017 13:33 #185486
by Keithy
Now if I was to ask what is wrong with your vacuum system to make it ridiculously expensive don't think I'm looking for a roll around on the floor......but what's wrong with it that makes it a bit spendy?
I miss Michael Winner on TV adverts.
Who said you were slating peoples opinions....for me you'd be entitled to have your own.Russ6334 wrote: Whoa this isn’t face book!
Time to create page: 0.096 seconds
