4wd vacuum system issues
- Russ6334
22 Oct 2017 12:54 #185414
by Russ6334
4wd vacuum system issues was created by Russ6334
Hi all
I’ve been wading and driving through mud and now my 4wd isn’t working I’d say 99% of the time. Occasionally it will work again but if you go to 2wD and back to 4WD you lose it again.
I stripped down the vacuum system, found 3 filters choked with mud so replaced them with hose up high to stop it happening again.
Also blew through the check valve to the filter that seems to be working and replaced any dodgy hoses.
Finally I stripped the electrical fittings and cleaned them replacing them with loads of vaseline, the transfer box ones were done with Vaseline before it ever went in water.
Now the issues are the same! Sometimes 4WD flashes on the dash other times it doesn’t even flash or light up but all the time the 4WD isn’t working
It’s really annoying as I bought it just for lanes!
Any ideas? I gather it’s a common problem!
Thank Russ
Thank Russ
- Thank you received: 706
22 Oct 2017 13:06 #185415
Replied by jackonlyjack on topic 4wd vacuum system issues
Go with manual locking hubs problem solved
Jack
Jack
- Russ6334
22 Oct 2017 13:30 #185416
by Russ6334
Replied by Russ6334 on topic 4wd vacuum system issues
I think it’s the easier option! And 10m job!
If I get MH I can leave them in 4x4 all the time as the front prop is free wheeling
Only when putting in 4wd would it engage and since the vehicle hasn’t got a locked diff I wouldn’t chew the diff up on road either?
Am I right??
Am I right??
22 Oct 2017 14:32 #185420
Yes
If you wanted to you can make the vac hubs permanently locked save you cash
here is a post about it but pics are missing due to photobucket
www.bigjimny.com/index.php/forum?view=to...d=55862&limitstart=0
Jack
Jack
- Russ6334
22 Oct 2017 20:20 #185432
by Russ6334
Yeah I read this but it’s confusing?
You Bush where the spring is? Surely that’s what the spring is for?
Does this mean the vacuum system holds the hubs open? If so when it fails it would fail in 4wd?
Because the spring keeps the drive engaged? Else the spring would be on the opposite side to disengage?
22 Oct 2017 21:02 #185433
Sent from my Nexus 6P using Tapatalk
Replied by mlines on topic Re:RE: 4wd vacuum system issues
The locking mechanism is held in place by magnets. The vacuum pulls the locking mechanism on or off but if the vacuum leaks after the hub has locked out does not matter as the magnets do their workRuss6334 wrote: Yeah I read this but it’s confusing?
Time to create page: 0.108 seconds
