Knocking noise ???
26 Sep 2017 04:28 #184500 by Lambert
Replied by Lambert on topic Knocking noise ???
It would have to be a very significant amount of play in a slip joint, like a visually observable deflection in the straightness of the entire propshaft. I have a pto shaft for the tractor and I can flex that abou 6 or 8mm and it runs quiet.
26 Sep 2017 18:05 #184534 by Me and my Jimny
Replied by Me and my Jimny on topic Knocking noise ???
Hmm I can see it move but not as much as I think you're describing.
I think I need to take the tbox guard off to get a better look if there's any movement at the joint going in there.
I guess it could be inside the tbox, are there any visual signs if something was going wrong in there ?
26 Sep 2017 18:45 #184535 by Me and my Jimny
Just read an interesting old post on another site suggesting to put a tbox in neutral. So I guess if I did this but had the regular gear box in 1st I could rule something out
If it's still knocking then it would rule out the rear prop or diff, but if it doesn't knock then it would rule out the main prop and my gearbox mount swap
But I guess either way it could still be the tbox ?
14 Oct 2017 17:51 #185222 by Me and my Jimny
Finally got round to getting it out for another look, and doing this neutral test I can see, or hear, that as soon as the clutch is released the middle prop starts turning and the knocking starts.
The uj's seem ok at both ends but I can rotate the prop about 10-20 degrees back and forth. Is this normal or does it indicate a certain fault ?
Just trying to narrow it down before taking it to garage. I reckon I could do stuff to the other props but this one looks a bit tricky to get to
Time to create page: 0.082 seconds
