Knocking noise ???
23 Sep 2017 19:23 #184401 by Me and my Jimny
Hi Guys
A few weeks ago my wife was driving the Jimny, probably faster than its comfortable at, says she heard a bang and now it has a knocking noise that gets faster as you go faster.
I could see signs that the rear engine mount was going and have swapped it out but the knocking noise is still there.
Another inspection and I can see oil and Greece leaking from the front right ball joint. I've seen the wiki pages about the kingpin and/or wheel bearing but neither mention the knocking.
Is it also a symptom or am I still looking for the source ? Any other ideas what to check ?
Cheers
Paul
24 Sep 2017 09:22 #184419 by Busta
Replied by Busta on topic Knocking noise ???
It won't be the front axle as nothing is rotating unless you are using it in 4wd.
It should be comfortable up to 80mph so I doubt it was anything that wasn't already on it's way out. Check the intermediate and rear props for play in the UJs.
24 Sep 2017 19:59 #184435 by Me and my Jimny
Replied by Me and my Jimny on topic Knocking noise ???
Thanks for the pointer, I got back underneath again today and just tried moving everything.
There's some sort of joint in the prop from the transfer box to the rear diff and it has done play in it. It's covered by a rubber cover which I didn't wang to remove in case it's not the problem. Is this likely to be it or should there be some play on this joint ?
Regards
Paul
24 Sep 2017 20:01 #184436 by Me and my Jimny
Sorry for the typos, bloody predictive nonsense
25 Sep 2017 17:58 #184476 by Riccy
Replied by Riccy on topic Knocking noise ???
Me and my Jimny wrote: Thanks for the pointer, I got back underneath again today and just tried moving everything.
Regards
Paul
The rear prop has a grease nipple on it i think. check near the transfer box end. its on the side of the UJ. That will fill the expansion joint in the prop and stop any noise from that, but i have one that is really loose and it doesnt make any undue noises once up to speed.
Check the exhaust. mine bangs on bits here and there. mainly the towbar.
Is it possible it was driven on the road in 4x4? that would usually damage the t-box, but could damage a CV or half shaft in the front axle, possibly leading to it leaking diff oil at the front end?
25 Sep 2017 22:06 #184497 by Me and my Jimny
Ha ha, no, she tries to off road in 2 wheel drive if that's what I left it in when I park, but I don't think she would have had it in 4 on the road.
I don't think the bit I'm referring to is the Uj or grease nipple. I just did an image search and on one it calls it a slip yoke, covered by a slip yoke boot. Would play in the slip yoke cause a knocking noise ?
Time to create page: 0.110 seconds
