front axel
16 Aug 2017 20:22 - 16 Aug 2017 20:26 #183449 by paul2u
Replied by paul2u on topic front axel
thank you for your help riccy much appreciated my jiny is a 2005 and all standard nothing at all modified all wing and door pannels in place as they should be and as i said not been in a bump yet i can live with the odd scrape or two on big bumps but i am the kind of lad thats like to solve problems even if its the hard way lol i know that the axel is out some place and given that i done seem to have many options to work on i am now wondering if i renewed the original springs and shock weather that mit help some being that they might be that bit stronger and not go down so easy cheers paul
ps the wheels are the standard wheel from suzuki for that yeat three spoked alloys
Last edit: 16 Aug 2017 20:26 by paul2u.
17 Aug 2017 07:07 #183456 by Lambert
Replied by Lambert on topic front axel
It's front to back that's off. Sounds like something is bent or worn on one of the hockey sticks either the chassis or axle mounting bracket or the holes for the bolts are ovaled. You are absolutely certain that it hasn't been smashed?
17 Aug 2017 09:51 - 17 Aug 2017 09:53 #183458 by paul2u
prety sure its not been smashed or even bumped i had an insurance check on it before i got it and it was clear!! not only that when it was on the ramp at the garage it was checked all over the front end for signs of anything but there was nothing to see it all looked perfect as it should for a one lady owner infact its the best underbody jimy i have ever had with no rust at all in the boot department lol i am going to be replacing the springs and shocks tomorrow.
altho the garage could not see any thing on the track control bushes i now think i am going to replace them anyway as you say something could be oval and that wont be seen till dismantled , the tracking was out a small bit but i had that fixed cheers paul
Last edit: 17 Aug 2017 09:53 by paul2u.
17 Aug 2017 16:26 #183467 by facade
Replied by facade on topic front axel
Have you checked that it isn't the bumper is further back on one side?
There are crumple zones built into the chassis rails right at the front, and despite what the owner tells you about never having a bump, and the small size, most jimnys have front bumpers that look like they have been used to knock walls down.
17 Aug 2017 17:22 #183468 by paul2u
its got nothing to do with the bumper m8t the gap difference is at the back of the wheels towards the front doors right where the front mud flaps would go in between the mud flap bolts and the Tyre there is about ten mill of difference between offside and near side , the woman i bought it off never said anything about crashes it was insurance company checks , having that said myself and my garage cant find any sign at all of anything that would indicate it having a bump , i am going to drop the track control arms tomorrow to check them out if the steel inserts are one sided /oval as Platinum Boarder points out then this would indeed cause the problem i think cheers paul
17 Aug 2017 17:59 #183470 by mlines
Replied by mlines on topic front axel
paul2u wrote: hi guys was wondering id somebody can help me out with my head banging problem , i have been a jimny man for 30 years or so l
Are we talking about what us Brits call a Jimny as these have only been around since 1998 - just under 20 years :)
Check the axle itself. It is really easy to bend the long axle tube by clunking it on a kerb. This can sometimes be characterised by the small inner axle oil seal continuously leaking oil even when freshly replaced
Time to create page: 0.103 seconds
