front axel
16 Aug 2017 15:52 - 16 Aug 2017 16:06 #183443
by paul2u
front axel was created by paul2u
hi guys was wondering id somebody can help me out with my head banging problem , i have been a jimny man for 30 years or so i use them for general run about and for their ability to work well inn the wood dragging out trees ect for my hungry fire they have served me well with the last one dying of old age at 187,000 miles on the clock
i went to up size the tyres on my current jeep to 225/70/15 generel grabbers on coming home down my rough tracj i heard a scrap noise from the front off side wheel upon investigation i found the wheel hitting the wing fixing bolt head after futher investigation i now find there is a difference between the near side and off side as tho the axel was sitting squint ,in other words not sitting square to the body i thought right away that the track control arm bushes might have gone but thats not the case i took it to my mot man at the garage and he saw nothing wrong with the bushes and said that this was strange
by my calculation i thing there is something like about 20 mill of difference in the gap , have you any idea how this can be , the jeep has been in no crashes at all !! well not yet any way lol
Last edit: 16 Aug 2017 16:06 by paul2u.
- X8GGY
16 Aug 2017 16:25 #183444
Replied by X8GGY on topic front axel
Has it been lifted?
That would move the axle to one side as the panhard rod 'shortens' (long side of Pythagoras triangle)'
16 Aug 2017 16:33 #183445
by paul2u
Replied by paul2u on topic front axel
not to my knowledge but i do lift my jimnies from time to time with the tractor depending what i want to do but not had this one up yet nor have i ever come across this problem with other jimnies that i have lifted maybe it depends where you lift them from cheers paul
16 Aug 2017 16:41 #183446
Replied by Riccy on topic front axel
I think Dave means 'suspension lift kit' by lifted.
I had the same problem after fiddling with the suspension. eventually sorted it with a set of adjustable panhard rods and some castor corrected sway arms. The over-size tyres you have will make it worse/more obvious.
If you have a broken spring or worn bushes on sway arms that could do it also possibly.
16 Aug 2017 16:53 - 16 Aug 2017 16:54 #183447
by paul2u
ha ha trust me to get the wrong lift lol no its not been lifted i tend to keep them pretty standard apart from tires the problem was not apparent with the 205/70 15 and i have only just noticed now i have fitted the 225 /70/15 i dont have a broken spring and my garage tells me it would pass an mot for bushes , the panard rod on mine is none adjustable do you think one would square it up cheers paul
ps how do you guys upload pictures i tried using photo bucket but the never appeared
Last edit: 16 Aug 2017 16:54 by paul2u.
16 Aug 2017 17:22 #183448
If it hasnt got a lift kit on, then an adjustable panhard kit would be too long even on its shortest setting.
It probably means some bumper trimming. Are the wheels standard or off-set of some kind? and what year of jimny is it?
When I ran 215/75R15 I noticed it a little, but wasnt a problem. Your tyres are 1.1% smaller diameter than that, but 4.7% wider. I found that once i had fitted 30mm wheel spacers to the 215 size tyres i got catching problems on front and rear of front arches. back were fine however.
Tyre size info:
tiresize.com/tyre-size-calculator/
Photos: i just use the option to add attachements when posting. If replying use the 'action' menu instead of 'quick reply' and select reply. i think the forum hosts the pics so keep the file sizes down if poss.
Tyre size info:
