R72 to R7ME gearbox swap question
- Venter
28 Apr 2018 15:51 #192252
by Venter
What are you going to seal it with (resin spec, etc)?
Replied by Venter on topic Re:R72 to R7ME gearbox swap question
Riccy wrote:
mlines wrote: Have you sealed the cap inside the prop flange?
Not yet,
that is the first thing i will try. Its in bits for welding, when time allows i will try that
28 Apr 2018 16:35 #192253
Replied by Riccy on topic Re:R72 to R7ME gearbox swap question
Arldite :laugh:
tried superglue on the last one i had with the same problem but that didnt work.
Im thinking 2pac resin type stuff, so a good clean and then some arldite glue stuff will hopefully get me going again.
unless anyone has a better suggestion?
- Venter
28 Apr 2018 17:11 #192255
by Venter
Replied by Venter on topic R72 to R7ME gearbox swap question
Cheers
Just been looking into it, and reckon I'll go for this stuff (unless anyone has doubts...)
www.amazon.co.uk/gp/product/B005O0366Q/r...&smid=A28CP5FJLXYWDR
29 Apr 2018 06:18 #192263
Replied by Riccy on topic R72 to R7ME gearbox swap question
Cheers Venter, that stuff looks good.
BTW... you can remove the intermediate prop without draining the gearbox oil if the rear of the car is on ramps (or at least 20cm higher than the front). Dont just pull it out on the level as you will get covered in gearbox oil. So says the voice of experience :laugh:
- Venter
29 Apr 2018 10:12 #192267
by Venter
Haha, thanks for the heads-up. I doubt that would be as much fun as it sounds!
Riccy wrote: Dont just pull it out on the level as you will get covered in gearbox oil. So says the voice of experience :laugh:
- YangMan
09 Jun 2018 07:20 - 09 Jun 2018 07:21 #193319
by YangMan
Replied by YangMan on topic R72 to R7ME gearbox swap question
Hi am new to the forum
Am wondering how can the reverse switch be modified from r72 to r7me gearbox? Is there an adapter available online or what can I do to ensure the reverse light worked after doing the swap. Thanks
Last edit: 09 Jun 2018 07:21 by YangMan. Reason: Typo error
Time to create page: 0.225 seconds
