R72 to R7ME gearbox swap question
- Jay-t
09 Apr 2018 11:48 #191480
by Jay-t
Replied by Jay-t on topic R72 to R7ME gearbox swap question
How did the installation work out
Did everything work out fine ?
10 Apr 2018 18:00 #191535
Replied by Riccy on topic R72 to R7ME gearbox swap question
Bad of me, I forgot to update the post after installing.
Yes its all working ok now. There have been a few changes in the meantime to accomodate larger tyres, ARB lockers and the rocklobster transfer box, but the R7me box is working fine. Clutch has held up fine as well (excedy standard one).
The weld i made on the bracket to adapt to the newer mounting position has worked, but was slightly off where it should be (too far back and the donor mount should have been welded onto the BOTTOM of the new bracket to get the height correct). This means i have a HD transfer box mount in there instead of the standard rear engine mount, No big loss as they are cheap to replace if it goes and stronger. I forgot to take pics of how it went together but the original pictures show it fairly well.
if it was to be done to a standard VVT jimny with normal tyres then i would say it needs to have the transfer box and the diffs swapped as well to match the gearing properly. I did use the earlier 3.9 diffs for the lockers in mine to match the rocklobster box and tyres. works very well
Riccy
Riccy
- Jay-t
10 Apr 2018 21:37 #191545
by Jay-t
Sounds great I want to put in another gearbox on my 2006 jimny my r72 does not go into 1st gear and a grinding noise in third and lightly in 4th .. I’ve managed to get a samurai gear box but I’m not sure how it will work .... any ideas ?
11 Apr 2018 05:36 #191552
SJ gearbox wont work. you need to stay with the M series combination (R72 for a M13 VVT, R7me for non VVT M series).
Do you mean transfer box? that can be fitted but wont help much for noisy gears in main box.
11 Apr 2018 07:19 #191556
I came to more or less the same conclusion as i was looking at different solutions when my R72 broke down this weekend.
If you swap to R7me from R72 you will have to change the transfer and diffs as well.
I have the Rocklobster available from a SJ413 project but if i where to use it in my VVT even with a R7me swap i would have to change the diffs or go 31" tires.. Or cope with high rpm on highways.
When i plan to continue using my 235's i am better off with the original setup and just change the gears in my original transfer box.
Less work and probably not so different price compared to bying the diffs/axles.
Due to popular demand the R7me is half the price of the R72 though.
And now there is no R72 available in Norway as I prolly bought the last one..
Replied by yakuza on topic R72 to R7ME gearbox swap question
Riccy
- Jay-t
11 Apr 2018 11:36 #191565
by Jay-t
Well where I leave have no spares no gearboxes no kits no nothing so I have limited to no options
Time to create page: 0.311 seconds
