Lambda Sensor Question
11 May 2017 06:31 #181135 by mlines
Replied by mlines on topic Lambda Sensor Question
  • Venter
11 May 2017 07:37 #181137 by Venter
Replied by Venter on topic Lambda Sensor Question
Thanks Martin, on way to local auto parts store to see if they have one of those, otherwise it'll be eBay...
  • mickt
12 May 2017 19:53 #181186 by mickt
Replied by mickt on topic Lambda Sensor Question
The Lambda sockets are no good for sensors that have been on an age. I have the set and all three that fitted just splayed open as the cutouts are too big. I tried blow torch no good and ended up with a can of freezer and the manifold in a vice. I cut a one mm slot in a ring spanner , its just wide enough to allow the cable through then with a good tube extension it came off.
  • Venter
12 May 2017 22:50 #181191 by Venter
Problem has been sorted.
In the end I bought one of the sensor sockets, but it was too tall so couldn't get the ratchet handle to slot in, as space is very limited for the lower of the two lambda sensors. Luckily I bought an extended length 23mm spanner at the same time, so after a night and day of soaking in plusgas, it gave way with a fair bit of persuasion.
At least I've got the socket in my toolbox, can use it on the upper sensor one day if need be.
Time to create page: 0.089 seconds
