Lambda Sensor Question
- Venter
10 May 2017 18:54 #181119
by Venter
Lambda Sensor Question was created by Venter
Anyone know what size spanner fits the 2nd lambda sensor (the lower one on the catalyst, "HO2S-2" in the service book))?
I've tried a 21mm but too small, so am thinking it's 23 or 24, but want to make sure I buy the right one tomorrow.
Car is 2003 (M13AA)
Car is 2003 (M13AA)
- Thank you received: 706
10 May 2017 19:18 #181120
Replied by jackonlyjack on topic Lambda Sensor Question
i used 22mm ring spanner
also if you cut the clip bit off the connector it will then fit through the spanner ring
maybe just maybe you may need some scaffold tube to move it
i slotted 600mm of tube onto spanner
Jack
Jack
The following user(s) said Thank You: Venter
- Venter
10 May 2017 20:19 - 10 May 2017 20:19 #181122
by Venter
Replied by Venter on topic Lambda Sensor Question
Thanks Jack.
Wish I could get my breaker bar and socket in there, the mole grips gripped well but just didn't have the leverage, its stuck pretty tight in there.
What do you mean by cut the clip off? I just see the sensor sticking out of the cat and the wires leading from it, no clip (see pic).
I'm considering cutting the wires to so I can get the socket on, then just splicing wires back together and insulation taping them.
Last edit: 10 May 2017 20:19 by Venter.
10 May 2017 20:28 #181123
the connector is up back of head
it clips to a metal plate
the clip you cut off is the one that holds it to the plate
will post a pic soon
Jack
Jack
10 May 2017 20:35 #181124
- Venter
10 May 2017 20:48 #181126
by Venter
Ok, now I see.
Will give it a go in the morning, cheers!
Time to create page: 0.108 seconds
