Overdrive off light
10 Feb 2017 00:11 #177905
by Casey
Overdrive off light was created by Casey
Recently bought an automatic Jimny amd have noticed the the overdrive off light occassionally comes on without the button on the gearshift having been pressed. I'm guessing it isn't meant to do this, but can anyone tell me why it's happening?
- ZookFastback
11 Feb 2017 06:55 #177918
by ZookFastback
Replied by ZookFastback on topic Overdrive off light
Wish I had an overdrive on my Jimny, would love to drop down from 4100rpm @ 100 k's to... anything !
11 Feb 2017 10:59 #177921
by facade
Replied by facade on topic Overdrive off light
In the early jimny, the switch was connected directly to the light, and the gearbox controller.
In the twin cams the switch connects to the controller, and the controller triggers the light.
You can ground the monitor plug and the OD off light will flash out a trouble code, I don't think it comes on by itself to indicate one though.
Most likely the wire that goes up the gearlever is damaged and earthing out somewhere, or water has got into a connector.
The following user(s) said Thank You: Casey
Time to create page: 0.074 seconds
