winch
- TomDK
25 Jan 2017 20:32 #177263
by TomDK
Replied by TomDK on topic winch
It certainly is.
But even though it is possible to go greenlaning on worn out AT tyres, most still run on good MT tyres or better. The right toys/tools just makes it all a bit more fun
25 Jan 2017 20:42 #177266
Replied by Daniel30 on topic winch
Agreed
25 Jan 2017 21:08 #177269
by Busta
Most people go greenlaning without a winch... and you certainly don't need a fast winch if it's for just in case you get stuck. Better a light and reliable 3,500lb winch then a cheap 13,000lb anchor.
The biggest issue for self recovery is having the winch on the front. The easiest route out of trouble is almost always backwards.
- TomDK
25 Jan 2017 21:36 #177270
by TomDK
I don't disagree with you.
But a reliable 3500 lbs winch? Is that a winch from a well known brand like Warn? I'm guessing such a winch costs just as much as a 6500-8000 lbs winch made in China. Some China made winches are of good quality, some not so good.
But one thing is for sure. Such a tiny winch, no matter how you use it on a Jimny will also be pulling at it's maximum. It's not even designed for a 1100 kgs vehicle. So compared with an equally serviced 6500 lbs winch I'm quite sure it wont last as long.
25 Jan 2017 21:50 #177273
by safari
if u worry u die if u dont worry u still die so why worry
tks for the help . i got the winch for free so i will give it a go .i will be using it only in case of emergency
25 Jan 2017 22:04 #177275
by Busta
I seem to remember Idiotmobil had a cheap 3500lb winch on the front of his Jimny for ages. He eventually got a bigger winch but the 3500 was still working so he put it on the back.
Time to create page: 0.101 seconds
