winch
25 Jan 2017 16:50 #177247 by safari
winch was created by safari
hi everyone will a 3500lb winch be enough to pull me out of problem . i am not going winch challenges with it just if stuck a pull
if u worry u die if u dont worry u still die so why worry
25 Jan 2017 17:45 #177248 by Busta
Replied by Busta on topic winch
For your average stuck-in-a-rut problem and getting out of a mudde 3500lbs will be perfectly adequate. You only need big winches on a Jimny if you are getting stuck on purpose ;)
  • TomDK
25 Jan 2017 18:28 #177250 by TomDK
Replied by TomDK on topic winch
Depends what kind of problem you'r stuck in. If it's in a bog with mud up over the tyres, then it's not nearly enough. But it's okay for minor recovery. Although, I'd probably go for a 4000/4500 lbs as a minimum.
  • 1066Boy
25 Jan 2017 19:59 #177256 by 1066Boy
Replied by 1066Boy on topic winch
Snatch block to double the power? :)
  • TomDK
25 Jan 2017 20:27 #177260 by TomDK
Yes a snatch block is a great thing to have. But, If your winch is painfully slow even on a single line pull. Imagine the time it will take for a recovery with a snatch block :dry: :lol:
  • Daniel30
25 Jan 2017 20:28 #177261 by Daniel30
Replied by Daniel30 on topic winch
A recovery is a recovery :woohoo:
Time to create page: 0.090 seconds
