Engine management light
20 Jan 2017 22:33 #177088
by KJS
Replied by KJS on topic Engine management light
Had this the other day, it's the oxygen sensor at the manifold. Replaced the sensor and warning gone.
Keith
Keith
- Pendragon
21 Jan 2017 19:36 #177123
by Pendragon
Replied by Pendragon on topic Engine management light
Thanks Keith,
Just ordered one off the net, did you have any issues getting the old one out, or was it pretty straight forward..?
Thanks again...
Thanks again...
22 Jan 2017 09:47 - 22 Jan 2017 09:48 #177141
by KJS
Fairly straightforward, l didn't have a correct socket - a 22mm with a cut out for the wire. So l removed the manifold silver cover and also took the little bracket off the rear of the head which is a 10mm bolt that both sensors connect to the loom on, made the access a lot easier.
Then back together again, no problems since and whole job took about 1/2 hr.
Keith
Keith
Last edit: 22 Jan 2017 09:48 by KJS. Reason: Spelling
- Pendragon
22 Jan 2017 13:10 #177146
by Pendragon
Cheers Keith,
Will give it a go this week when the replacement sensor turns up.....
Time to create page: 0.160 seconds
